Android 4.2.2 from rikomagic mk802III for ug802 clone!
Hi all. I have install android 4.2.2 ( from 27.08.2013)from rikomagic mk802III on this ug802 cloneeverything works like a charm,smooth , but the stick is getting hot(only when i run antutu) and reboot.I downgrade the cpu clock to 1200mhz(interactive mod) but no succes.Sometimes freeze on boot and need to replug the stick to start .Can somebody mod this rom to work fine on this clone? I like this rom . Thank you!
Tags: None
Originally posted by dorud82 View PostHi all. I have install android 4.2.2 ( from 27.08.2013)from rikomagic mk802III on this ug802 cloneeverything works like a charm,smooth , but the stick is getting hot(only when i run antutu) and reboot.I downgrade the cpu clock to 1200mhz(interactive mod) but no succes.Sometimes freeze on boot and need to replug the stick to start .Can somebody mod this rom to work fine on this clone? I like this rom . Thank you!
Hi, where do you downloaded the rom from?
I think that I have the same stick.
Thnaks.
There are currently 1517 users online. 1 members and 1516 guests.
