MX10 android box help
i have MX10 4gb/64gb it has android 8.1 i want to downgrade to 7.1 noghat i got all driver and android on geekbuying 1st time it connected with factory tool 1.6 and it started upgrading when it goes 15% it failed after that my box just red light on nothing else no connected with computer i install alot of drivers but the factory tool not detect my box just red light on plz help me i am worried about my box because 2 month ago i bought it plz some one help meTags: None
Hello,
So the Factory Tool is not the right one to Burn these Box.
You have to use Android Tool also you have to erase the Box incl. Bootloader before Downgrade.
You can Download the Tool here: --> https://drive.google.com/file/d/16AQ...ew?usp=sharing
Start the Tool connect your Box in Upgrade Mode an do the following:
1.: Click on "Upgrade Firmware"
2.: Click on "Firmware" and select your Android 7.1 Firmware
3.: Now Click on "Erase Flash"
After that your Device is in Mask Rom Mode
4.: You can now Downgrade your Device with the Press on "Upgrade"
That?s it.
If it not Work proper then also connect the Power Cord after you put the Device in Upgrade Mode.
Neomode
Hi mate try factory tools 1.39 and try driver assistance 4.3 and only use USB port 4
here is the link
http://chinagadgetsreviews.blogspot....-v139.html?m=1
Have a look here for some firmware too
I have the some problems..
but i have resoult...
For first you mush use firmware d4
http://geekbuying.mediafire.com/file...80528.img/file
(ddr4) e not r1 o r2...(ddr3)
And flash with use factory tool only entering in maskroom mode ...
There are currently 3591 users online. 1 members and 3590 guests.
