[ROM] Mecool KM9 Stock & Nano Nexus ROM (Android 8.1)
#31.1Guest commented16 February 2019, 21:20Editing a commentKM9 isn't rooted, so you can't use dd. You've either got to replace recovery.PARTITION in a burn package and flash with USB Burning Tool or you can create a signed OTA update file like I've done here: https://1drv.ms/u/s!AoqocX31ecnXgbIdSaKxLK3e-SPboA
Originally posted by exotic34 View PostGuest
Here is the link KM9-AOSP-9.0-IMG-20190107 software : https://mega.nz/#F!rA0wyS5Q!psbgnSAfZokyn7Y5sSkLJA
Not the Atv software. Ugly launcher and no voice remote..
This software is it possible adapted to nexus software and atv software?
Do you have work about this software? Thank you..
Guest I try it as OTA update and this not compatible for Android 9 version with firmware KM9-PI-V1.20190107.175858.img. See my screenshot, i'm have errors with mount System and build.prop
Yes, the OTA update is only designed to update a KM9 with Oreo (SDK 27), not Pie (SDK 28). This is because the partition map is different. To my knowledge, no OEM has yet released Pie firmware, although there is that AOSP-9.0-V1.20190107.175858 build floating around.
You should be able to flash the Amlogic burn package with USB Burning Tool, though.
Originally posted by Benna View PostI found that sound is not working , I mean I cant change volume. Not with stock remote or my air mouse. I am trying android 9 now
Στάλθηκε από το MI PAD 4 PLUS μου χρησιμοποιώντας Tapatalk
Hi,this rom.is very good,please try to fix Chromecast and tvremote,as i saw,others menage to make thia working...if you need beta tester i will help
Poslano sa mog Mi A2 koristeći Tapatalk
I use the both Nvidia Shield TV and Nexus Player firmware releases as a model for what's needed, but the kernel and drivers are worthless because they're made for different processor architectures. Actually, the Xiaomi Mi Box is more interesting for porting, since it's made on an Amlogic reference board...but for an outdated processor and it's locked down pretty tight.
None of these Google Certified boxes are going to help us run Netflix or Google Cast on the KM9, since you need device certification. That's only made possible with keys installed at the factory that are unique to the device. They're not even included in the OEM firmware.
Yes Magendanz,Trickle is wright.
When will you have the rom from nvidia shield.
Can you make the remote control to work with netflix?
The problem is that you're not using the Android TV version of Netflix, but the one designed for tablets and phones with touchscreens. Unlike the ATV version, this Netflix app cannot be driven entirely from the remote. It assumes a touchscreen (or mouse). About the only thing you can do is enter mouse mode, where the dpad on your remote controls the pointer position, but that's pretty damn slow and awkward. You might also try an air mouse.
So mr Magendanz there is no hope to get the device verification some time on this box?Thanks for the interest.
Hi @Magendanz,
I sent something by PayPal because you're responsible for making my 2 Mecool KM9's useful again. Thanks.
I bought 2 as christmas gifts but I found they were pretty useless when I went to set them up for my kids.
I flashed them with your Nano Variant: BURN PACKAGE and they work great now.
I replaced the control with an air mouse.
There is one thing that I can't fix in settings - the android nav controls at the bottom of the screen (triangle-circle-square) stay with every app.
The notification bar at the top slides away but the footer nav doesn't.
In older android tablets these was a setting to toggle full-screen but that's missing from the settings on this ROM.
I downloaded an app to force full-screen but the footer nav would disappear and reappear immediately.
Is there a setting I'm missing to auto hide this nav-bar?
Cheers
Simon66
Well, that inability to hide the navigation bar I listed in the notes of the original post. Honestly, I'm surprised that VideoStrong didn't include a setting (or the ability to drag from the edge to show and then collapse with a button like Beelink did).
One thing to try: There's a setting in framework-res.apk called config_showNavigationBar in /res/values/bools.xml that's currently set to true. You could set that to false, but that would disable the nav bar permanently. Setting /res/values/dimens.xml/navigation_bar_height to "0.0dpi" would probably also do that.
Ref: https://android.googlesource.com/pla...ues/config.xml
There are currently 1496 users online. 0 members and 1496 guests.
