Another H6....
Many thks to gearbest for sending me the device to play
Many Thks to my beta testers trebor
READ THE BUGS SECTION FOR UNNECESSARY QUESTIONS!!!!
Changelog SCV1:
- Simple rom
- Cleaned it...!
- Added Nova launcher
- Fixed Google logins, give it up to 5 secs for it to open when you press login... dont go crazy and start pressing like a ... well... you know...
- Optimized the max i could.
- Fixed adb connection.
- Added AndroidTV screensaver ( default 5 min, you can change the time in settings/display/sleep )
- Added google assistant.
- Added double press home button to bring app switch... use the left or right arrows of the remote to close the open apps...
- Long Press Menu button to open search.
- And a lot of others sh*ts...
- Enjoy it
Bugs SCV1:
- Many more i bet........ but must i simple cant fix myself with out the source!
Download:
- DOWNLOAD HERE Tanix TX6 SCV1 ROM
- MD5: 70348F5D1B57582D25BA70D8A24029B2
Install instructions:
- Well... Just use PhoenixSuit select the IMG.
- Do not press Upgrade button...
- Press reset hole button ( near usb ports ) keep it pressed
- And Connect the USB cable to USB2 port and the flash should start
- The Flash app will ask you something, press yes the 2 times it does...
THIS ROM DELETES ALL YOUR DATA SO DO A BACKUP!
USE AT YOUR OWN RISK!
Enjoy it!
