[ROM] Tanix TX6 - SCV1 Custom Rom ( Normal Android 7.0 )
Hi Superceleron. Love your work! I have a quick question, maybe you can answer. I bought the Tx6 that was suppose to have Android 7 on it. When it arrived, it already had 9. I tried to down grade it with your rom, and several others.And every time, it loads with a huge banner across the top of the screen saying "This device is not yet activated yet, please contact your vendor" the only thing that makes it go away is loading 9 again. Any ideas?
Originally posted by MyVision View PostHi Superceleron. Love your work! I have a quick question, maybe you can answer. I bought the Tx6 that was suppose to have Android 7 on it. When it arrived, it already had 9. I tried to down grade it with your rom, and several others.And every time, it loads with a huge banner across the top of the screen saying "This device is not yet activated yet, please contact your vendor" the only thing that makes it go away is loading 9 again. Any ideas?
If you do that maybe register the box?!
It'S just an idea you could test
Then tell me how it went
well guys... the problem here is that tanix (other company behind it) had the bright idea to put a "protection" in their roms...
I could remove it, but i cant since "other company behind it" are partners to the company i work for... so you can imagine what it would happen if i do so...........
I dunno if they added the same to their android 9 build...!
Originally posted by superceleron View Postwell guys... the problem here is that tanix (other company behind it) had the bright idea to put a "protection" in their roms...
Enviado do meu Beelink GS1 atrav?s do Tapatalk
Hi all,
thx a lot for the clean and fast image !!! happy to got rid of Alix UI....
I can?t login to Play Store in this Rom ? Login Button availible, but does not work ?!
Internet is connected, i can install APKs like Chrome, but no chance of Logging in to Play Store.
Uninstalled updates, installed Play Store APK, but no luck...
I even can?t add a google account ?!
Any help/idea is highly appreciated !
BRLast edited by usti; 08 May 2019, 20:41.
There are currently 2614 users online. 1 members and 2613 guests.
