Leave the loader unchecked.
Pipo U1 Pro RileyROM 1.1
You need an misc.img in every ROM...but they are all the same, so if it is missing....use one from the other ROM.
Leave the loader unchecked.Randy
Originally posted by rrileypm View PostYou need an misc.img in every ROM...but they are all the same, so if it is missing....use one from the other ROM.
i already flash the rom and i must say its very nice, just one thing bootanimation is set to potrait mode, and the boot image after pipo is messed up...
Sorry about that...give me a few days to fix the boot animation. That's one of the drawbacks of not having the tablet to test on.Randy
Originally posted by rrileypm View PostSorry about that...give me a few days to fix the boot animation. That's one of the drawbacks of not having the tablet to test on.
Originally posted by lothian77 View Posti have installed this rom and wanted to say that also with this it is impossible to use youtube app.
after few minutes all videos start buffering and becomes impossible to see a video until the end, so i would like to ask if there can be a solution for this...
(watching youtube in the browser works fine)
I may just delete it. If you want YouTube ...just add it from the play store. Some of these old apps just need to go away.Randy
i must say, this rom was the best smooth, i am not a gamer but i tried to run asphalt 8 from the market and i dont encounter any problem, just one thing is there any way to play nba2k13? i heard on skyworth tablet they manage to make this work they said some libs are missing,sorry boss riley i deleted lots of system/app that i dont actually use and add some important apps on the system/app like seeder and greenify, nofrills and add some lines on the build.prop. antutu benchmark score was not stable (as always) but the highest score i get was 14958, nenamark 45.5 fps, no problem using mxplayer+customcodecs, i use the default parameter which is 2 gb, just a friendly reminder before flashing read the instruction carefully specially if you are from kitkat base rom... generally this rom is supperb...
I will try to get you one tonight.Randy
OK, here you go. Just open notepad and copy this into it. Save as "parameter3" into the RileyROM folder.
Code:FIRMWARE_VER:4.0.4MACHINE_MODEL:U1 Pro MACHINE_ID:007 MANUFACTURER:RK30SDK MAGIC: 0x5041524B ATAG: 0x60000800 MACHINE: 3066 CHECK_MASK: 0x80 KERNEL_IMG: 0x60408000 #RECOVER_KEY: 1,1,0,20,0 CMDLINE: console=ttyFIQ0 androidboot.console=ttyFIQ0 init=/init initrd=0x62000000,0x00800000 mtdparts=rk29xxnand:0x00002000@0x00002000(misc),0x00004000@0x00004000(kernel),0x00008000@0x00008000(boot),0x00008000@0x00010000(recovery),0x00100000@0x00018000(backup),0x0003a000@0x00118000(cache),0x00600000@0x00152000(userdata),0x00002000@0x00752000(kpanic),0x00112000@0x00754000(system),-@0x00866000(user)
Randy
hi
Originally posted by rrileypm View PostOK, here you go. Just open notepad and copy this into it. Save as "parameter3" into the RileyROM folder.
ei boss, thank you for your effort,..keep up your very good work...
boss
got last question, the last time i flashed this rom i change the recovery.img because i am not sure and i did not bother to ask you if this rom has already have custom recovery???coz i know you were a busy person thats why i changed it without asking, do i have to do that again?? or this one already have?
edited:
never mind boss, i already red the README FIRST.TXT, but there is no file CWMrecovery.img, i still have my current cwm so i guess i am going to use that.. thanks
and to those who want to use the 3gb parameter, dont just copy and paste, i dont know if this will have a bad effect on the unit, but if you just look at it
this is supposed to be two lines...
as what i said i dont know if this will have a bad effect on the unit but just to make sure..Last edited by jh3ss; 19 April 2014, 16:41.
When flashing the whole ROM, it's better to flash the stock recovery. That way, all of the partitions get formatted correctly. If you want to flash a custom recovery later, just flash it by itself from the flash tool.
I've been using TWRP, lately and although there are still a few glitches, it works for me.
You just have to get the version that most resembles your tablet...CPU and screen resolution.
This is Abdul_pt's TWRP thread: LinkRandy
Originally posted by rrileypm View PostWhen flashing the whole ROM, it's better to flash the stock recovery. That way, all of the partitions get formatted correctly. If you want to flash a custom recovery later, just flash it by itself from the flash tool.
There are currently 3253 users online. 0 members and 3253 guests.
