I bricked my TV UG007b stick by a wrong flash , normally i was always able to bring it back
By holding reset button and plugging usb cable at the same time , but this time it didn't work
So i refered to an old post here regarding one user bricked his UG007b stick and NEOMODE
Informed him to short pins 5-8 , but i am not sure what is ment by this
Does this means linking pins 5 and 8 or linking pins from 5 to 8 (i.e 5 ,6 and 6,7 and 7,8)
Or may be something else , can any one please help ?
(The following pin count are counted from the top left corner of the nand chip)
The solution was to connect (short) pins 5 and 6 with a needle , use another needle to connect pins 7 and 8 , while connecting the pins simultaneously plug in the usb cable , then it will boot
Into flash mode.
It is the same solution suggested before but i thought to write it in more details for newbies.
hello opengl
I am a novice in the field.
I also have the problem that I can not flash my ug007b.
can you tell me exactly must show (which side) which I bridge pins (see picture) I have 2 marks, are you the right?
I've understood everything
1 leave pin 5 +6 over bridge short and get rid of
2 pin 5 +6 and 7 +8 pin bridge and keep
3 connect usb cable
is that correct?
what happens then?
tool with which I can then continue to work. I have to keep going with stockrom einerr or can I use a customrom.
thanks for help me
Into flash mode.
Thank-you so much for this information. I have been spend a long time to unbrick my MK809iii and you helped me!
Also, I got the correct firmware in http://www.freaktab.com/showthread.p...rer-s-firmware wich is the original one.
Thank you
