It is:
Rooted
Debloated
English set as default language
Google Play Store fixes added
Init.d support added
Busybox commands added
cifs.ko md4.ko and tun.ko added for VPN support
Performance tweaks added
CWM Recovery added as an option
2, 4, 6, 8, 10, 12gb user app space parameters as an option (default is 2gb)
Pipo Launcher included
Multi-User support added (but not tested on this device)
Thanks to Tattman65 for the boot animation
Thanks to Finless for the flash tool
Thanks to Fun for the generic CWM Recovery
Thanks to Pr0xZen for the First Time User's Guide
You might notice some things are different in the ROM kit.
1. I included the Rockchip Batch Tool as an alternative for resetting you tablet into flash mode. You can also use this tool to flash the stock ROM if you need to, for some reason.
2. I also included a template for you to build your own CWM flashable ROM. There is a readme file in that folder that tells you how it's done. I would not recommend changing to a different ROM using this feature, it is just a way to re-flash this ROM without having to use PC. You can't change parameter settings through CWM.
3. The default recovery.img is stock recovery. As an option, I included the generic version of CWM Recovery...you can flash it instead of the stock recovery by just renaming the files...recovery.img to stockrecovery.img and cwmrecovery.img to recovery.img before flashing.
Enjoy!!!!!!
Download
If this ROM makes a difference for you, please consider a donation to support future RileyROM's here at Freaktab.com Donate!!!
