I have a TX8 Max AP6255 Android box. It started crashing the other day so I did a factor reset. The box rebooted and sat on the erasing screen all night. I rebooted it the next day and the box would not boot at all. I have downloaded the firmware from the website (both beta and normal) along with the USB_burning_tool. I start the software and select the image. I then connect the USB cable to the box and the laptop. The burning tool says Device connected. I then plugged the power into the box. I select Start. It gets to 7% Formatting then fails with the error [0x32030201]UBoot/Get result/DiskInitial error. I'm using burning Tool 2.1.6. Any help would be great so I can get my TV shows back :-)
Cannot Flash TX8 Max
Please help guys.
I have a TX8 Max AP6255 Android box. It started crashing the other day so I did a factor reset. The box rebooted and sat on the erasing screen all night. I rebooted it the next day and the box would not boot at all. I have downloaded the firmware from the website (both beta and normal) along with the USB_burning_tool. I start the software and select the image. I then connect the USB cable to the box and the laptop. The burning tool says Device connected. I then plugged the power into the box. I select Start. It gets to 7% Formatting then fails with the error [0x32030201]UBoot/Get result/DiskInitial error. I'm using burning Tool 2.1.6. Any help would be great so I can get my TV shows back :-)Tags: None
Your device is recognized by Amlogic USB Tool, which is a good thing. (only soft brick)
Did you research how to un-brick your device?
Have you checked multiple sources to ensure you have the proper or newest firmware(hopefully with bug fixes).
Good.- Re-download firmware try to verify that the zips are not corrupt.
- Disable your Antivirus software.
- Remove any USB peripherals(my USB mouse interferes with Burn Tool).
- Try flashing.
- Failing above...try holding the reset button until you pass the 7% mark..or hold it the entire way through the process until 100%.
- Failing the above, as you hold the reset button you may need to plug in the power supply while you plug in the USB cable ( 3 hands).
Thanks ReaperMan. I have tried searching TX8 Max un-brick but I didn't find anything. I have tried the above but it still sits at 7%. Below is the error log.
[10:00:00 206][HUB4-4][Err]--ResetDevEx ret=-5 error_msg=libusb0-dll:err [reset_ex] could not reset device, win error: The system cannot find the file specified.
[10:01:32 697][Global][Inf]--Update HUB4-4 \\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[10:01:32 697][HUB4-4][Inf]--Update device path
[10:01:32 697][Global][Inf]--Update HUB4-5
[10:01:32 697][HUB4-5][Inf]--Update device path
[10:01:32 697][Global][Inf]--Update HUB4-6
[10:01:32 697][HUB4-6][Inf]--Update device path
[10:01:32 717][HUB4-4][Inf]--Device is connected
[10:01:32 717][HUB4-4][Inf]--Close device handle 0x0000064c
[10:01:32 778][HUB4-4][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000970
[10:01:37 850][HUB4-4][Inf]--0-7-0-16
[10:01:37 850][HUB4-4][Inf]--CheckFileRunState succeed
[10:01:37 850][HUB4-4][Inf]-- low_power
[10:01:37 850][HUB4-4][Inf]--Send command success
[10:01:37 850][HUB4-4][Inf]--Read command status success
[10:01:37 850][HUB4-4][Inf]-------------Download meson1.dtb-----------
[10:01:37 850][HUB4-4][Inf]--Enc(0xadfc318c)
[10:01:37 850][HUB4-4][Inf]-- download mem dtb normal 137216
[10:01:37 850][HUB4-4][Inf]--Send download command success
[10:01:37 876][HUB4-4][Inf]--Read command status success
[10:01:37 882][HUB4-4][Inf]--Transfer complete
[10:01:37 882][HUB4-4][Inf]--Send download get_status command succeed
[10:01:37 899][HUB4-4][Inf]--get_status success
[10:01:38 401][HUB4-4][Inf]-------------ERASE FLASH-----------
[10:01:38 401][HUB4-4][Inf]--disk_initial 1
[10:01:38 401][HUB4-4][Inf]--Send command success
[10:02:38 402]AmlLibusb usb_bulk_read len=512, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[10:02:38 402][HUB4-4][Err]--usb_bulk_read len=512, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[10:02:38 402][HUB4-4][Err]--Check command return failed
[10:02:38 402][HUB4-4][Inf]--Failure : 1, FailureMax : 3
[10:03:02 085][HUB4-4][Err]--ResetDevEx ret=-5 error_msg=libusb0-dll:err [reset_ex] could not reset device, win error: A device attached to the system is not functioning.
[10:03:02 085][HUB4-4][Inf]--Failure : 2, FailureMax : 3
[10:03:26 083][HUB4-4][Err]--ResetDevEx ret=-5 error_msg=libusb0-dll:err [reset_ex] could not reset device, win error: A device attached to the system is not functioning.
[10:03:26 083][HUB4-4][Inf]--Failure : 3, FailureMax : 3
[10:03:28 429][HUB4-4][Err]--[0x32030201]Uboot/Get result/DiskInitial error
[10:03:28 429][HUB4-4][Inf]--Close device handle 0x00000970
[10:16:48 033][Global][War]--Close tool
[10:16:48 564][Global][Inf]--Burning thread HUB4-4 end run
[10:16:48 564][Global][Inf]--Burning thread HUB4-4 exit
[10:16:49 080][Global][War]--Controler exit
[10:17:02 670][Global][Inf]--Get system Info :
[10:17:02 670][Global][Inf]--Windows Version: Microsoft Windows 10, Bit: 64
[10:17:02 670][Global][Inf]--Scan usb device
[10:17:02 670][Global][Inf]--Aml scan WorldCup Device
[10:17:02 670][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
[10:17:02 670][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_05741025& rev_05#3&11583659&2&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:02 670][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&2d0ef637&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:02 780][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1d751bd1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:02 780][Global][Inf]---------->[Port0]Other device
[10:17:02 780][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:02 780][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:02 780][Global][Inf]---------->[Port3]NoDeviceConnected
[10:17:02 780][Global][Inf]---------->[Port4]NoDeviceConnected
[10:17:02 780][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:02 780][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:02 780][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
[10:17:02 780][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_05741025& rev_05#3&11583659&2&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:02 780][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1b142e6e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:02 843][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1247b8d9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:02 843][Global][Inf]---------->[Port0]NoDeviceConnected
[10:17:02 843][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:02 843][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:02 843][Global][Inf]---------->[Port3]NoDeviceConnected
[10:17:02 843][Global][Inf]---------->[Port4]Other device
[10:17:02 843][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:02 843][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:02 843][Global][Inf]--Scan USB host controller complete
[10:17:02 843][Global][Inf]--Update data center with HubMap
[10:17:05 566][Global][Inf]--User click open button
[10:17:09 133][Global][Inf]--Image path C:\Users\Administrator\Desktop\TX8-Max_Android-7.1\TX8-Max_Android-7.1.www.tanix-box.com.img
[10:17:09 133][Global][Inf]--OpenImg C:\Users\Administrator\Desktop\TX8-Max_Android-7.1\TX8-Max_Android-7.1.www.tanix-box.com.img
[10:17:14 672]Parse platform.conf
[10:17:14 688][Global][Inf]--Parsing burning package
[10:17:14 688][Global][Inf]--Load configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp
[10:17:14 688][Global][Inf]--Parse burning configuration file C:\Program Files (x86)\Amlogic\USB_Burning_Tool\temp\burn_config.xm l
[10:17:14 688][Global][Inf]--Get burning key
[10:17:19 268][Global][Inf]--User click start button
[10:17:19 268][Global][Inf]--SetErase
[10:17:19 268][Global][Inf]--Enable burning 1
[10:17:19 268][Global][Inf]--Scan usb device
[10:17:19 268][Global][Inf]--Aml scan WorldCup Device
[10:17:19 284][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
[10:17:19 284][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_05741025& rev_05#3&11583659&2&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:19 284][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&2d0ef637&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:19 382][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1d751bd1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:19 382][Global][Inf]---------->[Port0]Other device
[10:17:19 382][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:19 382][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:19 382][Global][Inf]---------->[Port3]NoDeviceConnected
[10:17:19 382][Global][Inf]---------->[Port4]NoDeviceConnected
[10:17:19 382][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:19 382][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:19 382][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
[10:17:19 382][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_05741025& rev_05#3&11583659&2&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:19 382][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1b142e6e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:19 448][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1247b8d9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:19 448][Global][Inf]---------->[Port0]NoDeviceConnected
[10:17:19 448][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:19 448][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:19 448][Global][Inf]---------->[Port3]NoDeviceConnected
[10:17:19 448][Global][Inf]---------->[Port4]Other device
[10:17:19 448][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:19 448][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:19 448][Global][Inf]--Scan USB host controller complete
[10:17:19 448][Global][Inf]--Update data center with HubMap
[10:17:21 371][Global][Inf]--Catch DBT_DEVICEARRIVAL
[10:17:21 371][Global][Inf]--Scan usb device
[10:17:21 371][Global][Inf]--Aml scan WorldCup Device
[10:17:21 371][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
[10:17:21 371][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_05741025& rev_05#3&11583659&2&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:21 371][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&2d0ef637&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:21 479][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1d751bd1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:21 479][Global][Inf]---------->[Port0]Other device
[10:17:21 479][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:21 479][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:21 479][Global][Inf]---------->[Port3]NoDeviceConnected
[10:17:21 479][Global][Inf]---------->[Port4]NoDeviceConnected
[10:17:21 479][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:21 479][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:21 482][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
[10:17:21 482][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_05741025& rev_05#3&11583659&2&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:21 482][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1b142e6e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:21 482][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1247b8d9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:21 482][Global][Inf]---------->[Port0]NoDeviceConnected
[10:17:21 482][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:21 482][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:21 482][Global][Inf]---------->[Port3]\\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[10:17:21 485][Global][Inf]---------->[Port4]Other device
[10:17:21 485][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:21 485][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:21 485][Global][Inf]--Scan USB host controller complete
[10:17:21 485][Global][Inf]--Update data center with HubMap
[10:17:21 485][Global][Inf]--Insert new hub4
[10:17:21 485][Global][Inf]--Update hub4 device data
[10:17:21 485][Global][Inf]--Update HUB4-1
[10:17:21 485][HUB4-1][Inf]--Update device path
[10:17:21 485][Global][Inf]--Update HUB4-2
[10:17:21 485][HUB4-2][Inf]--Update device path
[10:17:21 485][Global][Inf]--Update HUB4-3
[10:17:21 485][HUB4-3][Inf]--Update device path
[10:17:21 485][Global][Inf]--Update HUB4-4 \\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[10:17:21 485][HUB4-4][Inf]--Update device path
[10:17:21 488][Global][Inf]--Begin thread for HUB4-4
[10:17:21 488][Global][Inf]--Update HUB4-5
[10:17:21 488][Global][Inf]--Burning thread HUB4-4 start
[10:17:21 488][HUB4-5][Inf]--Update device path
[10:17:21 488][Global][Inf]--Update HUB4-6
[10:17:21 488][Global][Inf]--Burning thread HUB4-4 begin run
[10:17:21 488][HUB4-6][Inf]--Update device path
[10:17:21 488][HUB4-4][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x00000938
[10:17:21 543][HUB4-4][Inf]--CloneImageProxy
[10:17:21 543][Global][Inf]--OpenImg C:\Users\Administrator\Desktop\TX8-Max_Android-7.1\TX8-Max_Android-7.1.www.tanix-box.com.img
[10:17:21 543][HUB4-4][Inf]--Connect path=Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26/P0/P0/P3
[10:17:21 543][HUB4-4][Inf]--Start burning...
[10:17:21 604][HUB4-4][Inf]--------------ERASE BOOTLOADER------------
[10:17:22 112][HUB4-4][Inf]--2-2-0-0
[10:17:22 112][HUB4-4][Inf]-------------Download DDR.USB-----------
[10:17:22 112][HUB4-4][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[10:17:22 630][HUB4-4][Inf]--Control write pll reg1 0xd9000000:0x00005183
[10:17:23 133][HUB4-4][Inf]--Control write pll reg1 0xd9000000:0x000000b1
[10:17:23 635][HUB4-4][Inf]--Control write pll reg1 0xd9000000:0x00005183
[10:17:24 147][HUB4-4][Inf]--Write initial succeed
[10:17:24 147][HUB4-4][Inf]--Upload encrypt at 0xc8100228
[10:17:24 147][HUB4-4][Inf]--ulValue = 0xadfc318c
[10:17:24 147][HUB4-4][Inf]--Read encrypt value succeed
[10:17:24 147][HUB4-4][Inf]--Transfer complete
[10:17:24 147][HUB4-4][Inf]--Run at address 0xd9000000
[10:17:24 163][HUB4-4][Inf]--RunInRam succeed
[10:17:24 493][HUB4-4][Inf]--2-2-0-0-0-1-0-0
[10:17:24 493][HUB4-4][Inf]--CheckFileRunState succeed
[10:17:24 493][HUB4-4][Inf]--runResult:0x 0,paraMagic:0x7856efab
[10:17:24 493][HUB4-4][Inf]--ddrCapacity:0x c00
[10:17:24 493][HUB4-4][Inf]--ulValue = 0xadfc318c
[10:17:24 493][HUB4-4][Inf]--Download UBOOT.USB buffer at 0x0200c000
[10:17:24 613][HUB4-4][Inf]--Transfer complete
[10:17:24 829][HUB4-4][Inf]--2-2-0-0-0-1-0-0
[10:17:24 829][HUB4-4][Inf]--Download DDR.USB buffer at 0xd9000000
[10:17:24 829][HUB4-4][Inf]--Transfer complete
[10:17:24 829][HUB4-4][Inf]--DownCheckPara succeed
[10:17:24 845][HUB4-4][Inf]--2-2-0-0-0-1-0-0
[10:17:24 845][HUB4-4][Inf]--Run at address 0xd9000000
[10:17:24 876][HUB4-4][Inf]--ReadCheckPara succeed
[10:17:24 876][HUB4-4][Inf]--2-2-0-0-0-1-0-0
[10:17:24 876][HUB4-4][Inf]--ulValue = 0xadfc318c
[10:17:24 876][HUB4-4][Inf]--Download DDR.USB buffer at 0xd9000000
[10:17:24 891][HUB4-4][Inf]--Transfer complete
[10:17:24 891][HUB4-4][Inf]--DownRunPara succeed
[10:17:24 891][HUB4-4][Inf]--2-2-0-0-0-1-0-0
[10:17:24 891][HUB4-4][Inf]--Run at address 0xd9000000
[10:17:26 244][Global][Inf]--Catch DBT_DEVICEREMOVECOMPLETE
[10:17:26 244][Global][Inf]--Scan usb device
[10:17:26 244][Global][Inf]--Aml scan WorldCup Device
[10:17:26 244][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
[10:17:26 244][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_05741025& rev_05#3&11583659&2&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:26 244][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&2d0ef637&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:26 350][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1d751bd1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:26 350][Global][Inf]---------->[Port0]Other device
[10:17:26 350][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:26 350][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:26 350][Global][Inf]---------->[Port3]NoDeviceConnected
[10:17:26 350][Global][Inf]---------->[Port4]NoDeviceConnected
[10:17:26 350][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:26 350][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:26 350][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
[10:17:26 350][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_05741025& rev_05#3&11583659&2&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:26 350][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1b142e6e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:26 350][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1247b8d9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:26 350][Global][Inf]---------->[Port0]NoDeviceConnected
[10:17:26 350][Global][Inf]---------->[Port4]Other device
[10:17:26 350][Global][Inf]--Scan USB host controller complete
[10:17:26 350][Global][Inf]--Update data center with HubMap
[10:17:26 350][Global][Inf]--Update hub4 device data
[10:17:26 350][Global][Inf]--Update HUB4-1
[10:17:26 350][HUB4-1][Inf]--Update device path
[10:17:26 350][Global][Inf]--Update HUB4-2
[10:17:26 350][HUB4-2][Inf]--Update device path
[10:17:26 350][Global][Inf]--Update HUB4-3
[10:17:26 350][HUB4-3][Inf]--Update device path
[10:17:26 350][Global][Inf]--Update HUB4-4
[10:17:26 350][HUB4-4][Inf]--Update device path
[10:17:26 350][Global][Inf]--Update HUB4-5
[10:17:26 350][HUB4-5][Inf]--Update device path
[10:17:26 350][Global][Inf]--Update HUB4-6
[10:17:26 350][HUB4-6][Inf]--Update device path
[10:17:26 384][HUB4-4][Inf]--Device is removed
[10:17:27 518][Global][Inf]--Catch DBT_DEVICEARRIVAL
[10:17:27 518][Global][Inf]--Scan usb device
[10:17:27 518][Global][Inf]--Aml scan WorldCup Device
[10:17:27 521][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C2D
[10:17:27 521][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c2d&subsys_05741025& rev_05#3&11583659&2&d0#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:27 521][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&2d0ef637&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:27 622][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1d751bd1&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:27 622][Global][Inf]---------->[Port0]Other device
[10:17:27 624][Global][Inf]---------->[Port1]NoDeviceConnected
[10:17:27 624][Global][Inf]---------->[Port2]NoDeviceConnected
[10:17:27 624][Global][Inf]---------->[Port3]NoDeviceConnected
[10:17:27 624][Global][Inf]---------->[Port4]NoDeviceConnected
[10:17:27 624][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:27 624][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:27 624][Global][Inf]--Host: Intel(R) 6 Series/C200 Series Chipset Family USB Enhanced Host Controller - 1C26
[10:17:27 624][Global][Inf]--DevPath:\\?\pci#ven_8086&dev_1c26&subsys_05741025& rev_05#3&11583659&2&e8#{3abf6f2d-71c4-462a-8a92-1e6861e6af27}
[10:17:27 624][Global][Inf]---->Roothub:USB#ROOT_HUB20#4&1b142e6e&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:27 624][Global][Inf]-------->[Port0]USB#VID_8087&PID_0024#5&1247b8d9&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}
[10:17:27 624][Global][Inf]---------->[Port0]NoDeviceConnected
[10:17:27 624][Global][Inf]---------->[Port3]\\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[10:17:27 627][Global][Inf]---------->[Port4]Other device
[10:17:27 627][Global][Inf]---------->[Port5]NoDeviceConnected
[10:17:27 627][Global][Inf]-------->[Port1]NoDeviceConnected
[10:17:27 627][Global][Inf]--Scan USB host controller complete
[10:17:27 627][Global][Inf]--Update data center with HubMap
[10:17:27 627][Global][Inf]--Update hub4 device data
[10:17:27 627][Global][Inf]--Update HUB4-1
[10:17:27 627][HUB4-1][Inf]--Update device path
[10:17:27 627][Global][Inf]--Update HUB4-2
[10:17:27 627][HUB4-2][Inf]--Update device path
[10:17:27 627][Global][Inf]--Update HUB4-3
[10:17:27 627][HUB4-3][Inf]--Update device path
[10:17:27 627][Global][Inf]--Update HUB4-4 \\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
[10:17:27 627][HUB4-4][Inf]--Update device path
[10:17:27 627][Global][Inf]--Update HUB4-5
[10:17:27 627][HUB4-5][Inf]--Update device path
[10:17:27 627][Global][Inf]--Update HUB4-6
[10:17:27 627][HUB4-6][Inf]--Update device path
[10:17:27 685][HUB4-4][Inf]--Device is connected
[10:17:27 685][HUB4-4][Inf]--Close device handle 0x00000938
[10:17:27 745][HUB4-4][Inf]--Open device handle \\?\usb#vid_1b8e&pid_c003#6&13387b0c&0&4#{a5dcbf10-6530-11d2-901f-00c04fb951ed} 0x000008a0
[10:17:32 812][HUB4-4][Inf]--0-7-0-16
[10:17:32 812][HUB4-4][Inf]--CheckFileRunState succeed
[10:17:32 812][HUB4-4][Inf]-- low_power
[10:17:32 812][HUB4-4][Inf]--Send command success
[10:17:32 812][HUB4-4][Inf]--Read command status success
[10:17:32 812][HUB4-4][Inf]-------------Download meson1.dtb-----------
[10:17:32 812][HUB4-4][Inf]--Enc(0xadfc318c)
[10:17:32 812][HUB4-4][Inf]-- download mem dtb normal 137216
[10:17:32 812][HUB4-4][Inf]--Send download command success
[10:17:32 828][HUB4-4][Inf]--Read command status success
[10:17:32 843][HUB4-4][Inf]--Transfer complete
[10:17:32 843][HUB4-4][Inf]--Send download get_status command succeed
[10:17:32 862][HUB4-4][Inf]--get_status success
[10:17:33 375][HUB4-4][Inf]-------------ERASE FLASH-----------
[10:17:33 375][HUB4-4][Inf]--disk_initial 1
[10:17:33 375][HUB4-4][Inf]--Send command success
[10:18:33 376]AmlLibusb usb_bulk_read len=512, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[10:18:33 376][HUB4-4][Err]--usb_bulk_read len=512, ret=-116 error_msg=libusb0-dll:err [_usb_reap_async] timeout error
[10:18:33 376][HUB4-4][Err]--Check command return failed
[10:18:33 376][HUB4-4][Inf]--Failure : 1, FailureMax : 3
[10:18:57 102][HUB4-4][Err]--ResetDevEx ret=-5 error_msg=libusb0-dll:err [reset_ex] could not reset device, win error: A device attached to the system is not functioning.
[10:18:57 102][HUB4-4][Inf]--Failure : 2, FailureMax : 3
[10:19:21 114][HUB4-4][Err]--ResetDevEx ret=-5 error_msg=libusb0-dll:err [reset_ex] could not reset device, win error: A device attached to the system is not functioning.
[10:19:21 114][HUB4-4][Inf]--Failure : 3, FailureMax : 3
[10:19:23 542][HUB4-4][Err]--[0x32030201]Uboot/Get result/DiskInitial error
[10:19:23 542][HUB4-4][Inf]--Close device handle 0x000008a0
There are currently 1133 users online. 0 members and 1133 guests.
