[ROM] BluePoisonATV S912 ""New and Improved""
Originally posted by X92-2GB View PostI thought in true ATV, you have language and inputs options in settings. Once you make latinIME default you can set latinIME to have the on screen keyboard disabled.
i guess you would need latinIME apk to side load if this firmware only has leanback keyboard.
It is running on Mecool BB2 Pro (3GB DDR4) - remote and bluetooth are OK.
Ram is OK
Code:# free total used free shared buffers cached Mem: 2842088 2565264 276824 0 19972 1398724 -/+ buffers/cache: 1146568 1695520 Swap: 511996 0 511996
https://play.google.com/store/apps/d...rogdvb.progtva
minixfreak Is there any way to enable it again?
Originally posted by zyxmon View PostIt is running on Mecool BB2 Pro (3GB DDR4) - remote and bluetooth are OK.
Ram is OK
minixfreak
I have checked it after reboot to be sure. Openmax does not work. More info - the same IPTV player with the same stream works (openmax) on the recently installed atvXperience v2H on 905W box (x96 mini).
Hey, I wish to try your new Rom's but before I go ahead on one of my devices could it get some confirmation, please.
I tried red poisons on Minix u9-h and it froze on first boot up wouldn't let me select English - United Kingdom, will Blue Potions work with Minix u9-h
and got a Minix U1, can I ask which 905 firmware is correct please W or X ???
and when u look at new chipset what can you do with the Shield TV, nothing wrong with it but worth a thought?
Cheers, look forward to giving it ago
There are currently 1974 users online. 4 members and 1970 guests.
