[Script] Auto frame rate for X96max ATV (and other clones)
Well, I don't know if it's expected but it looks something changed about Magisk/busybox, I thought I had broken something on my side by playing too much the sorcerer's apprentice, and I posted update just in case it happened to somebody else
A bit odd, but it looks now mksh/toybox has priority on boot time over ash/busybox, which caused much syntax errors especially on expressions, therefore I eliminated everything not compliant to both shells (e.g. $(( )) and [[ ]]), hence "compatibility fixes".
Originally posted by A.S._id View Post
In order for the folder to appear, you must enable init.d support in amlogic box tool. If it is on, try to off/on.(does init.d feature of that tool breaks Magisk service.d??)
There are currently 2359 users online. 2 members and 2357 guests.
