[Script] Auto frame rate for X96max ATV (and other clones)
thanks for this amazing "idea" and work
But, I noticed an issue with the script.
I found some movie that switch to incorrect "hz" so I debug a little and can say that:
some videos has xx fps show in the player and yy fps in "/sys/class/vdec/vdec_status" that you use to read the fps for the switch
Many time in tv show... maybe for the repack with different audio, but I have many videos that are 23.976 fps and "/sys/class/vdec/vdec_status" show me 25 fps and the opposite:
videos with 25 fps that "/sys/class/vdec/vdec_status" show 23.976 fps
Is there another "status"/ "class" that we can use confront to?
P.S.
In alternative, I'm working on a "modified version" of your script that use the KODI LOG for a confront of fps
I think the correct fps is the one that I see in the player (I use KODI 18.1) or I'm wrong ?
Thanks again.
That "approximate" fps is the only place I found so far (if there was a better one I'd have used it! And I guess I've not been the only one to search, even before I got that box only a month ago...), it has at least the advantage to work globally (compromise, as said), and I did not notice that much inconsistencies. I don't use Kodi white elephant though, that's maybe why
That said if you want to make it specific to Kodi, can't tell you but yeah, I hope it reports its own fps properly
Originally posted by A.S._id View PostYes, I'm know, I'm tried this custom kernel by anpaza from 4PDABut I don't understand why x96max or s905x2 can't support 4k2k 60p 4:4:4? I for laugh tried turn on NVidia Shield to my TV via the same hdmi cable and it working how to charm...
Originally posted by boxz0rd View Post
i thought the ATV GUI doesnt support 4k 60p 10bit but the videos will be displayed in 10bit anyway if the TV supports it, isnt that the case?
There are currently 2309 users online. 0 members and 2309 guests.
