mounting external sdcard as internal sd card
    Hello, has anyone managed to mount the external sdcard as internal card.
    I was googling around and i found out that if i edit the vold.fstab file i can get the result that i`m looking for.
    I opened the file and i found this two lines:
    "dev_mount flash /mnt/sdcard auto /devices/virtual/mtd/mtd9/mtdblock9"
    "dev_mount sdcard /mnt/external_sd auto /devices/platform/rk29_sdmmc.0/mmc_host/mmc0"
    I guess the first line mounts the internal nand memory as sdcard while the second line mounts the external_sd
    Now this is just guessing and i would like to be a little bit more sure before trying it, so if anyone knows pls share, if this are the lines that i need to swap to mount the external sdcard as internal?????
    Sent from my GT-I9300 using Tapatalk 4
    FIRMWARE & HARDWARE COMPATIBILITY LIST FOR ANDROID TV STICKS
    https://docs.google.com/spreadsheet/pub?key=0ApGXribKk_8gdEc3YnlmOHlfRlRQVUxFbkJ3Zzg3U EE&output=html
    My Plexi MK802IV mod
    http://www.freaktab.com/showthread.p...xi-MK802IV-mod
    i agree.yet i am a trainee.
      Re: mounting external sdcard as internal sd card
      ??????????????? What ?????????
      Sent from my GT-S7562 using Tapatalk now Free
        I done it a wile ago it worked for me http://www.freaktab.com/showthread.p...to+external+sd
          well i bought today a 16gb sdhc card class 10 and it says 30mb/s and it is really fast. i did the vold.fstab change and the external card was recognized as nand memory and till here all is good. i moved some apps to the new sd card from the settings\apps and after that restarted. here is the big trouble part. the apps that were moved were reporting as not installed. i have the icons on the home screen but when i try to open the application it just says that the app is not installed. is there any command to fix permisions or is it smth that i`m missing. i cant get to maked it work as it should. really need some help. thx
            What I did was, befor I applied the vold.fstab change I coppyed the entire internal sd card contents & pasted them to my 32Gb external sd then I applied the vold.fatab mod..but since you have already applied the mod your internal & external have already been swapped over so you may be able to do it the other way round,eg use es explorer navigate to mnt/external_sd copy the entire contents to mnt/sdcard that should work or you could un apply the vold.fstab mod reboot device coppy your entire internal sdcard to you external_sd card then reboot.
              i did copy all the system files from the sdcard to the externalsd before applying the mod. The problem is that all apps get installed on the main internal memory (which is 2gb) and after installing, i move them to the sd card (in this case it would be the externalsd). While the system is still on, the apps work ok but when i reboot the system and try to open the apps that i moved, comes out a message that says the app is not installed. ??????????????????????
              edit: it is like the app is moved to the internal nand (sdcard) which now is mapped as external_sd.
              it moves there and when i restart it tries to find the app from the external sd which now is mapped as sdcard.
                Hears my (modded) vold.fstab off my cx-919 for you to compare
                  http://docs.google.com/file/d/0BzqhK...it?usp=sharing
                  Well is the exact same thing with your vold.fstab. don`t get it why its not working. i have found a script for init.d that applies to the galaxy s4 for the memory swap. ill try to mod it and see if it fits for our devices. if it works im gonna share it here. cheers
                    well i have managed to copy the userdata.img material on the external micro sd card but i cant mount it.
                    what i want to do is that i want to mount it as the userdata.img. i manage to mount it at the /data point, the external micro sd card shows as internal memory and i can see that in the settings, but after 2 minutes the device reboots. any idea???
                      A pic of the mounted external card as internal memory on the mk802iv (8gb)
                        I think im mounting the external sd card with smth missing. I type from the terminal:
                        mount -r -w -t ext4 /dev/block/vold/179:1 /data
                        It gets mounted but i cant se the files or folders inside it
                          SDcard is vfat formatted usually. Your mounting with ext4. Wont work.
                            I formated in windows with the default fat32 format and just swaped the fstab lines and now i have a device with 6 gb internal memory (used the 6gb parameter) and 16gb sd card. NICE. Thx Bob.
                            I think im going to give up on the idea of using the external sd as main internal memory now that i switched it with the internal sd card
