MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Originally posted by trebor View Post
At this stage yes, that is correct.....
Note that that was the basic remote model km9
But
The KM9 Pro with Voice remote does have Widevine L1 I have just seen so it may work on the Pro Version
Still setting up at this stage.
Still Sorry we cannot reach netflix, no connection
Could be Mac address blocking or something else about these boxes more looking into
KM3 is still works 100%
Both KM9 with KM3 not at this stage no cast or Flix
Looks like it is what it is so far....,A better A9 ATV experience for KM9 instead of Mecool UILast edited by trebor; 28 April 2019, 08:07.
Originally posted by Magendanz View PostOkay, here's an Amlogic burn package (.img file) that I created by ripping the partitions from the KM3 that I received yesterday: KM3-PI-V1.20190320.img
Note that while I've converted the ext4 partitions to sparse format, the raw ones and boot images haven't been trimmed. I've compressed the file into a ZIP archive to reduce the download time, but don't confuse this with an OTA update. While it is a .zip file, you can't flash it with the system update app or stock recovery. Just unpack and flash the .img file with USB Burning Tool.
I've confirmed that it restores the OEM firmware successfully with Amlogic USB Burning Tool v2.1.7, but I haven't tested with Burn Card Maker.
I got the KM3 from Gearbest last weekend, and it seems to be working fine.
Issues:
A couple of issues I noticed where - (1) CEC (Consumer Electronics Control) does not seem to work right, as it turns of my connected TV but turns it on again. (2) the sleep function seems to put the box in a zombie state, whereby it stops displaying anything on the TV, the only way out seems to be performing a hard reboot by unplugging and plugging in the box.
YouTube and Amazon Prime
I was able to get Amazon Prime via Aptoide TV through Puffin as mentioned on this thread. YouTube works on 4K and Chromecast works well too.
Netflix
Zahir - the links you posted to Netflix aren't available. Could you post/DM or point me to the source for them, I'd like to try them out.
Originally posted by rayshan View PostI got the KM3 from Gearbest last weekend, and it seems to be working fine.
Originally posted by rakeshchn View Post
Does Amazon prime work in 1080p with Dolby digital + audio?
Couldn't check video quality in details, but looked to my eyes like it was 720 or may be 1080p
May be you installed mobile version of the app? Can you try the APK from https://rawapk.com/prime-video-android-tv-apk-download/
There are currently 1423 users online. 2 members and 1421 guests.
