It does not work on this box. So I'm back to using the netflix version 6.7 with the big red N
MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Zahir thanks for sharing the files. I have tried it on mecool m8s Pro L running on stock firmware which was last updated Aug 3rd.
It does not work on this box. So I'm back to using the netflix version 6.7 with the big red NLast edited by Hideiyoshi; 05 May 2019, 04:22.
Originally posted by rustyburnsfc View PostJust got the box today and have got prime and Netflix running sweet. The only thing is that the box keeps losing ethernet connection. Is this a common thing
Sent from my Pixel 2 using Tapatalk
Originally posted by Zahir View Postchainsmoker OK, one last time from me: check your inbox. Enjoy.
chainsmoker - glad it worked out for you. Seems clear that this fix is for the KM3 and none of the other Mecools.
Originally posted by sweetnonso View Post
On the KM3 box, if you have a 4k Netflix account, you will get 4k on this box. If your account is only HD account, then you will only get 1080p. Hope this answers your question.
There are currently 1806 users online. 0 members and 1806 guests.
