MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Originally posted by Jole View PostIs there any solution for problem with turning ON tv box, i changed to "shudown" with remote, and turned all sleep options off. But still can't wake device with remote? Please advise, do I need to not turning off device ever? Till update arive?
Thank you in advance for any solution
On a separate note, can I ask what you have heard about any new updates official or customer for this device cheers, are there any major flaws with the current stock Rom?
So my KM3 just arrived. Installed the netflix fix and ATV apps recommended here and just gives me "Sorry, your account can't be used on this device". I have the ultra hd plan by the way. Any help is welcome. Thanks
(Didn't update or anything since I got it. I'm on Kernel version 4.9.113 #4 Wed Mar 27 and Build PI.V1.20190320 release-keys)
Originally posted by Antoyax View PostSo my KM3 just arrived. Installed the netflix fix and ATV apps recommended here and just gives me "Sorry, your account can't be used on this device". I have the ultra hd plan by the way. Any help is welcome. Thanks
Envoy? de mon SM-N950F en utilisant Tapatalk
Originally posted by Antoyax View PostHow do I know if I have the stock firmware?
What i do for Netflix install...
Uninstall all Netflix app. Reboot your box. Install the 2 app and launch the patch. Reboot your box and for me it's ok... Maybee same for u.
Sorry for my english... I'm french
There are currently 2029 users online. 0 members and 2029 guests.
