netflix gives service unreachable error at startup (15002)
MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Drat! The app works fine at this end, so the blockage is with your box, I'm afraid.. The only thing left would be to reboot your router to see if that's where you're blocked.
Perhaps the process of installing other roms broke something, and the new fix might still work on an "unmolested" box.
I do regret I can't help you in your situation
Originally posted by Zahir View PostIt has long bothered me that some Mecool KM3 users have not been able to utilize the Netflix fix that I shared some time ago, while many more have. Since my box is one of those that cooperates with the fix, I haven't been able to trace the problem, which is likely related to Mecool's inconsistent designs. Several users have expressed their frustration with this situation.
I may shortly have a modest alternative for such KM3 users.
I have been able to modify a mobile version of the app to exploit Widevine L1 and run in Full HD. This mod doesn't depend on spoofing a Fire Stick or other device, and may therefore work on KM3s that don't take kindly to that approach.
There are two downsides: first, (and this isn't really a downside) you will need an air mouse or some pointing device for navigation as this is the mobile app. Second, there is a slight audio sync delay on some programs. It's very slight and not enough of an issue to spoil viewing for me, but it's there. I'm working to reduce it so that it's not noticeable at all.
I need a couple of volunteers who have not been able to get the original fix working to test my new alternative and report back.here. Do please recognize that I cannot guarantee it'll work on your boxes. I have used it on mine all morning, and believe that currently this is the only way to get Full HD Netflix on the KM3 without using my original fix. But although I have uninstalled my original fix files, I cannot be sure that they didn't change the box's configuration and made it receptive to this new mod. That is why we need to test the mod on a box that hasn't worked with the original fix.
If two/three volunteers step up, we can go from there. Ideally, your KM3 will be running the original factory firmware so that our test results are reproducible for others.
Thanks for the nice words. Yes. the ATV app is more user-friendly and represents the ideal. Still, workarounds based on the mobile app do bring HD streams in reach of users who would not otherwise have access. Glad you've found your own. If you get a minute, perhaps you might send me a link in my inbox to the one you're using so that I can compare it with mine?Last edited by Zahir; 10 August 2019, 10:53.
Originally posted by Zahir View PostThanks for the nice words. Yes. the ATV app is more user-friendly and represents the ideal. Still, workarounds based on the mobile app do bring HD streams in reach of users who would not otherwise have access. Glad you've found your own. If you get a minute, perhaps you send me a link in my inbox to the one you're using so that I can compare it with mine?
I reset the box again yesterday to attempt (4th) again at installin the 2 NETFLIX apk without success yesterday. I realised my box is unable to connect via ethernet hence i gotta fall back on 5gh b4 and after reset. I suspect maybe its the CAT6 cable or anyone else having the same issue?
Also anyone has the latest firmware think mine is still original firmware dated 200319
I'm interested with this box especially for 2 features : Netflix 4K (thanks for your great job Zahir) and Chromecast compatibility.
I read some reviews talking about some Chromecast limitations but with no further details.
Could you please explain me what are these limitations?
Thanks.
Cheers from Reunion Island.
Thanks.
Thanks.
Originally posted by Dicentim View PostHum thanks for your answers.
Not easy to choose every box has its downsides :
- KM3 : Netflix 4k seems hasardeous.
- KM9 pro : wifi seems terrible.
I'm afraid I'll make the safe choice : going for the Xiaomi Mi Box S, at least I'm sure Netflix 4K will be ok.
There are currently 7310 users online. 2 members and 7308 guests.
