MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Originally posted by Antoyax View Post
Thanks. I guess I can say it?s the same as mine right now and credit to Zahir.
Originally posted by Hideiyoshi View Post
The one provided by Bro Zahir was better I think. This one will start off in 480p then gradually into 1080p in approx 25 sec while Zahir version was immediate into 1080p
After the installation of the app "OnScreenClock" (app that displays the time on a corner of the screen available from Play Store) the front led of my Mecool km3 is continuously blinking in green. Amongst the different possible colours, the green one is not documented. Do you known its meaning?
Thank you!
Thank you!
What is this and how to do this? Is there a guide?
and you launch the program ,file import wv-key.img ,check widevine keybox , and check whether overwrite key and start ;-)
Originally posted by b2oba17 View Post
you need to install usb amlogic burning tool ,replace license folder in c:/programx86/amlogic/usb burning tool
There are currently 3053 users online. 0 members and 3053 guests.
