MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
diegori466 - here you go:
1. https://mega.nz/#!hC5EmKaI!0h4ktQ81I...BqmmIze3mzWBRk
2. https://mega.nz/#!oHJTEKjZ!XgRimd_bz...mrnLiKZ4bNPNUI
Will leave this up for 2 days.Last edited by Zahir; 13 January 2020, 20:18.
Originally posted by Zahir View Postdiegori466 - here you go:
1. https://mega.nz/#!QC4WVYYZ!0h4ktQ81I...BqmmIze3mzWBRk
2. https://mega.nz/#!ZHgUUaSQ!XgRimd_bz...mrnLiKZ4bNPNUI
Will leave this up for 2 days.Last edited by asegura074; 13 January 2020, 18:00.
asegura074 try those links in my original post (no.885) again. They should be working now. Let me know.
Originally posted by Zahir View Postasegura074 try those links in my original post (no.885) again. They should be working now. Let me know.
asegura074 - sorry, the post number with the fixed links is#528, about 8 posts earlier than this one. Those links are tested and working.
Originally posted by Zahir View Postasegura074 - sorry, the post number with the fixed links is#528, about 8 posts earlier than this one. Those links are tested and working.
thanks for all the useful posts in this thread!
Recently I flashed the rooted ROM provided in post #463 and first it seemed to work fine.
But while setting up the box I noticed that the stock remote isn't working well anymore. Not all button presses are recognized, which is really annoying, especially when browsing big lists or using the virtual keyboard. I didn't have this issue on stock firmware but I noticed similar behavior on CoreELEC and that's why I'm not using it anymore.
Did anyone else notice this and is there already a solution/workaround?
I heard that bluetooth voice control isn't working on the rooted ROM, but that doesn't matter for me, all I want is snappy remote control.
Update: Re-pairing the remote solved the issue. Should've tried that earlier.Last edited by randomt4sk; 30 January 2020, 21:31.
Hey geveryone,
I am having two minor issues, just wondering if there is a workaround for them..
On this box, is it possible to install browser while AndroidTV firmware is installed? - A guy I know is adamant that he had installed a browser on it, but he says it may have been before an update.
I tried a few things last night and while it goes through the motions, it says somethng like "not installed" at the end.
Quicksupport or Anydesk.
I have bought this box for my mother, and she hasn't got used to switching VPN on and off, so when she wants to watch something on UK's iPlayer I login and point (using the blue hand) to her what to click, which isn't the most dificult, but when she wants to update something it can be a pain.
Is there any update that I haven't seen or a workaround for either or any remote support app on AndroidTV firmware to allow me to remotely control the box. I saw that there was for 8.0 or maybe earlier, so maybe there is an update coming from them..
As i said, both issues are minor and not important, but if anyone knows of a way to do either, I would be grateful if they could post it.
Thanks.
There are currently 5105 users online. 0 members and 5105 guests.
