MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Originally posted by b2oba17 View Postyour netflix ,zahir is very good but for me not work with vpn and i need vpn ,i have returned to android 9 cracked and all work on my km9 pro netflix ATV UHD ,i'm sure have solution for km3 but ...not public
Originally posted by ezegalli View Post
Can you please send me in private how do you think I can solve the Netflix issue?
Originally posted by natzen View Post
I do have Netflix working in FULL HD using Android TV with the Zahir tablet version and also on Kodi... that thing is solved
Only thing i miss is the "best case scenario" where Netflix works with the Android TV Apk so i can use voice commands, have Netflix as a channel on the home screen and searching for shows and movies is much pleasant
Originally posted by b2oba17 View PostFor my rom only ,install with twrp - Magisk patched and ViPER4Android_FX ,Enjoy !
https://mega.nz/file/eJNH2YjC#CdMISa...XZmmDxEPRHHAzs
Here is an instruction on how to unlock the protection against modification of system files on the KM3, KM9 ATV firmware:
1. First of all, there must be a clean installation of the firmware, for example from the header, tested on KM9PRO rooted rom and a USB key.
2. The data in the data section will be deleted, so we make a backup copy.
3. Download AMLogicTools v6.0.0 and unzip it in C: \ AMLogicTools_V6.0.0
https://forum.xda-developers.com/dev...6925#downloads
4. Download Android Platform Tools and unzip it to the folder C: \ platform-tools
https://developer.android.com/studio...platform-tools
5. Download TWRP and copy it to the root of the flash drive.
https://mega.nz/file/iZ8VUawL#pYDFSQkYfBXPj6m7o3nCSaZdtOW2avdMGzN7iMVsY rI
6. Download vbmeta and decompress the contents of a USB key in the TWRP / BACKUPS / u211 / VBMETA folder https://mega.nz/file/rAtlhKoL#8qe6aKJTaee3ZZi7EjCD_OQsC7P2gysPJz1Fx5bnq 44
7. Then the most interesting:
a. We transfer the device to USB Burning Tool firmware mode.
b. We go to the Windows console in the folder C: \ AMLogicTools_V6.0.0 \ bin
c. run update.exe bulkcmd "fastboot" in the console, the device will go into fastboot mode
d. We go to the folder C: \ platform-tools (it is important to use the fastboot file from here)
e. running fastboot.exe devices should show that the device is found.
F. The following commands: fastboot.exe flashing unlock Fastboot.exe flashing unlock_critical. fastboot.exe getvar all at the end must be written securely: no, unlocked: all
8. We restart the console and begin recovery from the flash drive. We do it this way: hold the button in the audio jack connector and plug in the power, wait for TWRP 9 loads.
We restore the VBMETA section previously saved on the USB key.
10. Done, you can now modify the system files from the same recovery.
ENJOY !
if problem with link
There are currently 2480 users online. 1 members and 2479 guests.
