MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Hi guys,
I did update my s905x X96 android box with the firmware ( Android 9 for mecool km9) with the usb burner.
Unfortunately, it bricked my box and stays at boot. I tried to undo it using some other firmware via usb burner. But my usb burner is not recognizing it now. I tried reset button and nano chip. Didn't work at all. Any help is much appreciated.
Cheers,
Monu.
Originally posted by diazjesux View Post
I'm checking drm is l3
But, I have a bad news and it's impossible to recover drm l1 from l3. This means you will not be able to play video with drm protected.
Example: Netflix, Disney Plus, Amazon Video, etc.Last edited by diegori466; 06 October 2020, 02:47.
Cheers,
Monu.
Originally posted by diegori466 View Post
I read your comments., You put erase all in the usb burning tools. In my opinion, this can be the principal problem, because in the tutorial video indicated leave alone the configuration without modify something.
Any help is appreciated
???????After that Usb burning tool.have to detect, and you can install the correct firmware.
I understand, I have seen that with magisk this can be fixed, I managed to install magisk and get root but it is impossible for me to install the modules, since when restarting the bootloader is closed and the partition remains as read only
But, the modules can't recover drm l1, and although you could have installed both modules, it's impossible watch Netflix, disney or amazon prime video in version ATV, but the mobile version maybe if you can do it.
I write because also I lost my drm l1 in my Xiaomi mi box.
Originally posted by tuffno View PostMe and my friend has the exact same KM3 model. He can install Disney+ but its not to be found in my playstore. Tried to sideload the androidtv version from apkmirror but it refuses to play anything.
Any ideas?
Check your region in your tv box and the account google, and check if you friend don't use any vpn.
Region is Sweden on the Google accounts. Tried with both location services off and on. Even tried with Nordvpn to fake my location to the US. Still no Disney app on the playstore :/
Hi everyone, I am trying use the new launcher of Google TV, but I can't get success, so I write to ask if you're able to install without any problem. Actually, I am using the rom b2oba17, in my opinon, this is the principal reason.
So I ask you to install the new Google launcher in a non-rooted version such as one that is rooted
INSTRUCTIONS- download Home Launcher from Google Play: https://www.apkmirror.com/apk/google...me-android-tv/
- download Button Remapper from Google Play
- launch Home Launcher
- choose Launcher X from the options presented
- launch Button Remapper
- from the list of buttons to configure, choose home button
- from the list of categories, choose applications
- choose Home
That is it! Thanks
There are currently 2682 users online. 0 members and 2682 guests.
