MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
    Hi everyone,
    Any of you guys facing an issue with Netflix built [3.2.2-Android TV Mod] tork24 recently? Mine there is an error saying "This title is not available to watch instantly. Please try another title - 1044. I have tried to uninstall and install the Netflix apk back but the error still popped up whenever I played any series.
    I am using KM9 Pro with custom ROM KM9PRO.ATV9.V1.20191211.
    Cheers.
      Mecool km9 pro classic. Slimbox 8.3.2 Rom same problem.
        Hopefully someone experienced in this forum can help us.
          I have the same problem, I suppose that netflix blocks our tv box like as km3. Well, I suppose use the zahir version and i have the mecool v01 air mouse
            Well, this could be an fix to watch Netflix ATV in km9 pro or km3, although I don't try this. But, this could be the solution.
            Basically, you have to download the rom stock and the program amlogic tools.
            The program will allow edit some parts of system. You only modify the build.prop to seem as Xiaomi mi box s and then install three apps as system such as netflix black logo, netflix white logo and Burnkey tool.apk.
            After, you have use packaging option and save as (.img) to use usb burning tool and flash your custom rom.
            This will allow use the apps without any problem.
              This is an example vídeo:
                Interesting tips diegori466 . It is a bit complicated process for me to do it myself. Anyway thanks mate for the guide
                  ROM ANDROID 9 ROOTED WITH MIBOX SPOOF
                  soft: https://mega.nz/file/HBtklDhJ#mo-jVV...-YhNs7AKA1dD6M
                  Flashing img as usual via USB Burning Tools Do not forget to click Stop at the end of the firmware without overloading,
                  run the following commands in the Windows command line from the C:\ soft folder:
                  update bulkcmd fastboot
                  fastboot flashing unlock
                  fastboot flashing unlock_critical
                  fastboot oem reset
                  enjoy
                    fastboot oem reset
                    enjoy
                      https://mega.nz/file/PclyEJiD#ERaw8H...T0iuaPyY2zNRUY
                      ???????Do not forget to click Stop at the end of the firmware without overloading,
                      fastboot oem reset
                      enjoy
                        soft :
                        fastboot oem reset
                        enjoy
                          soft :
                          fastboot oem reset
                          enjoy
                          Power on and restart
                            Preview of android 10 rooted rom
                              OMG
                                the mibox rom imposible boots, this reboots constantly
