MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Originally posted by teksuox View Post
aqui esta el video https://youtu.be/er5rI6O4IQc ojala te sirva para identificar el tvbox pero yo compre un mecool km3 4G de ram con 64G de rom gracias
Probably km9 pro classic
no tendras el firmware para el km9 pro classic, gracias
Originally posted by takuma View Post
There is a topic in the on 4pda forum. I think this is the correct way to rooting the device, but unfortunately the links do not work
The link works, you have to read the instruction (translate) because board version compatibility. Make sure u know what your device specs first.
a file adb9.7z
after flashing root firmware from the link i gave, in UBT(the flashing tool) click stop and dont remove cable or close UBT yet, run unlock_bl.cmd until the command finish, just ignore the error displayed on cmd, then remove the cable and boot the device.
soft.zip
In any case, I updated the device with the ROM KM3_DDR4x_ROOT
And the device is rooted
Yes, my friend, this method is on the forum, but it does not work for rooting the device
Glad u managed to flash the rooted firmware. Does it preserve ur widevine L1, is it preloaded with russian app in any case?
I lost Security Level L1 previously and even after this update it remained unchanged l3
There are currently 1990 users online. 0 members and 1990 guests.
