MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Guest
Originally posted by diegori466 View Post
Originally posted by mAtvXk View PostSorry, i only corrected the links, ask OP for further assistance, because i don't own this device.
I have the next message "The service.sh module script does not appear to have run during boot".
Now, I need your help !!!!
Please Guest and b2oba17
Furthermore, I change the version of magisk, however I follow getting the same problem.
Originally posted by diegori466 View PostOk, I could install both modules with magisk, and I couldn't play Netflix ATV, however I could watch 4k netflix mobile version.
Thanks b2oba17
Thanks b2oba17
Hi, b2oba17 and natzen I could install both modules with yours commands to use twrp, however I never could boot the recovery. But, I tried once time install both modules with magisk, and this magically works. I don't have idea, but this was an incredible result. Now, you said sproof mi box Xiaomi or keys. But, I don't have idea how to do correctly. Coul you explain me please?Last edited by diegori466; 02 November 2020, 02:48.
Originally posted by diegori466 View PostHi, b2oba17 and natzen I could install both modules with yours commands to use twrp, however I never could boot the recovery. But, I tried once time install both modules with magisk, and this magically works. I don't have idea, but this was an incredible result. Now, you said sproof mi box Xiaomi or keys. But, I don't have idea how to do correctly. Coul you explain me please?
Originally posted by diegori466 View PostBut, this method doesn't work to netflix atv yabilo version, netflix automatically detects as device incompatible, but you can get 4k using magisk hide props as google pixel 4 to mobile version.
why you not test mibox in magisk hide props ?
How install modules in Magisk:
1. First you have to root accordinga @b2oba
2. Now, before you boots the rom with a10(root) you have to follow the next instructions:
3. Download AMLogicTools v6.0.0 and unzip it in C: \ AMLogicTools_V6.0.0
https://forum.xda-developers.com/dev...6925#downloads
4. Download Android Platform Tools and unzip it to the folder C: \ platform-tools
https://developer.android.com/studio...platform-tools
5.
a. We transfer the device to USB Burning Tool firmware mode.
b. We go to the Windows console in the folder C: \ AMLogicTools_V6.0.0 \ bin
c. run update.exe bulkcmd "fastboot" in the console, the device will go into fastboot mode
d. We go to the folder C: \ platform-tools (it is important to use the fastboot file from here)
e. running fastboot.exe devices should show that the device is found.
F. The following commands: fastboot.exe flashing unlock Fastboot.exe flashing unlock_critical. fastboot.exe getvar all at the end must be written securely: no, unlocked: all
And you have to return back step 5 and you have to do the same.
Finally, when you install a module you HAVE TO REBOOT OBLYGATORY. YOU NEVER HAVE TO INSTALL SEVERAL MODULES AT THE SAME TIME OR BOOT LOOP.
THIS IS ANSWER TO natzen
Originally posted by diegori466 View PostI did that with mi box s and the same problem using magisk hide propsbut netflix not work ... i think we need to modify build.prop
and add ro.nrdp.modelgroup=
Originally posted by b2oba17 View Post
i have tested with mibox S with all parameters i have receveid update notification from xiaomibut netflix not work ... i think we need to modify build.prop
There are currently 2340 users online. 0 members and 2340 guests.
