MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
The Yablio patched worked like a charm with Tork 34 Netflix version.
But suddenly it doesn't work anymore (NW-6-400 error).
I tried to reset my box (I use the B2oba17 ROM) but no way...
Worse I tried to install the mobile version posted by Yahir. This version needs an air mouse and can display till 1080p.
But not anymore on my box, it displays 480p max.
I'm afraid oir boxes were blacklisted by Netflix.Last edited by Dicentim; 21 March 2020, 20:09.
Teki, genek, Dicentim - yes, sad to say the Yablio fix has stopped working. It had a good run...
My fixed mobile version (air mouse required) is working fine on my KM3 at 1080p. But then I'm still on the stock factory rom, no rom changes since I bought the box.
Maybe one of you can try it again after uninstalling both previous apks? Run DRMInfo first. If it shows you have Widevine L1, the mobile app should work.
https://mega.nz/#!FDRHlYzB!oWU4Wn6NJ...sfY2Txh8UoHbOULast edited by Zahir; 22 March 2020, 16:41.
Yes, tribute to Yablio ! He comes from Reunion Island just like me, a small island in Indian ocean.
Zahir : unfortunately I tried your mobile apk (that worked ok with stock ROM in 1080p) but with B2oba17's ROM it only displays 480p.
I'll try to reflash stock ROM and say good bye to Auto framerate.
Edit : your mobile app is ok till 4300 kbps / 1080p.
My limitation was because of a network issue.
Thanks again Zahir !
Originally posted by natzen View Postvocal control on remote work now with rooted firmware just need to restart android tv service control
Could you please help me ?
???????Thanks.Last edited by Dicentim; 23 March 2020, 04:39.
Originally posted by cnuttin View PostSo is everyone getting the NW-6-400 error error now even with the patched apks?
mine was working fine for a year but just started doing this now.
Is there any way around this?
Envoyé de mon SM-N950F en utilisant Tapatalk
Originally posted by Teki View Posthello it doesn't work anymore ... you can go through Kodi by installing the Netflix addon. it's less pretty than the official app but it works
There's no way to patch the ESN with a modified APK or root access?
There are currently 2291 users online. 0 members and 2291 guests.
