MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
You could give Firefox a try.
There is a version optimized for FireTV which doesn't require an air mouse since it has an integrated cursor.
See http://github.com/mozilla-mobile/firefox-tv
Hola, quizas estes instalando la version de 64 o la x86 por eso te da problema de instalacion. Instala esta que está en su ultima version. https://www.apkmirror.com/apk/google...-apk-download/
Para poder utilizarlo tienes que tener un airmouse con teclado por que con el original no funciona. Yo lo tengo en mi km3 y va perfecto. Uso el Rii i25 mini y el Rii i8. Saludos!
Originally posted by Franic7 View PostHola, quizas estes instalando la version de 64 o la x86 por eso te da problema de instalacion. Instala esta que está en su ultima version. https://www.apkmirror.com/apk/google...-apk-download/
Hi, maybe you are installing the 64 or the x86 version so it gives you an installation problem. Install this one that is in its latest version. https://www.apkmirror.com/apk/google...-apk-download/
To use you have to have an airmouse with a keyboard because the original does not work. I have it in my km3 and it goes perfect. I use the Rii i25 mini and the Rii i8. Regards!
Originally posted by panchovilla View PostAnybody have the ROM for this box ?
I'm wondering if the previous version can be flashed to make it have TV OS/Google certification.
If you want to install KM3 and KM9 Pro roms on your regular KM9, you can...
But chromecast won´t work, neither netflix
Only thing you will get is Android 9 instead of Oreo, that´s it.
Originally posted by ezegalli View Post
Hello there,
There are currently 2934 users online. 1 members and 2933 guests.
