MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Well, here is the result after 7 connections with the prefix, she suddenly adopted the stock firmware KM3-PI-V1.20190320
flooded
Result 100% Burning successfully.
I disconnected from the computer, I connect to the TV and now .... the blue color appears cyclically and disappears and so constantly when you turn on .. the result is Brick !!! I ask someone for advice.
And this firmware does not work (img and ota firmware? https://www.getdroidtips.com/stock-f...ol-km3-tv-box/. Factory zero firmware is needed
I have not been able to get Amazon Prime to work. Sometimes if there is a preview before the show/movie that will play. Once my show/movie starts I might get audio & and black screen or just a black screen. I have tried several versions of the Amazon Prime off of Aptoid TV & non have worked. I don't understand how it works for some & not others. Any help is appciated.
KM3 Ver - 905300090316
Two of the many veersion that I have tried.
4.14.3-googleplay-armv7a
4.8.69-googleplay-armv7a
Originally posted by jadesse View PostI have not been able to get Amazon Prime to work. Sometimes if there is a preview before the show/movie that will play. Once my show/movie starts I might get audio & and black screen or just a black screen. I have tried several versions of the Amazon Prime off of Aptoid TV & non have worked. I don't understand how it works for some & not others. Any help is appciated.
Originally posted by Dicentim View PostHi, is the auto frame rate working for anyone? If yes could you please tell me the trick? Thanks
all work,cast ork
rooted and AFRD work for km9 pro and km3 ;-)
https://mega.nz/#!d4oA1AJb!cpdJ6HB8z...Y9i0RTkjVkDdiI
Hi b2oba17, welcome back !
Unfortuantely nobody managed to inject the keys to get Netflix 4K working on KM3, although we strictly followed your procedure.
We all got the same DiskInitial error, any further information please ? Thanks
[18:18:38 807][Global][Inf]--OpenImg C:\Users\PC-Dicentim\Desktop\Mecool KM3\wv-key\wv-key.img
[18:18:38 807][HUB3-4][Inf]--Connect path=Contr?leur d’h?te am?lior? USB ? circuit microprogramm? Intel(R) de la s?rie 6/C200 - 1C2D/P0/P0/P3
[18:18:38 807][HUB3-4][Inf]--Start burning...
[18:18:38 876][HUB3-4][Inf]-------------Download DDR.USB-----------
[18:18:38 876][HUB3-4][Inf]--0-7-0-16
[18:18:38 876][HUB3-4][Inf]--Upload encrypt at 0xc8100228
[18:18:38 891][HUB3-4][Inf]--ulValue = 0x6c9da79f
[18:18:38 891][HUB3-4][Inf]--Enctypt!
[18:18:38 891][HUB3-4][Inf]--No need download
[18:18:38 891][HUB3-4][Inf]--0-7-0-16-0-0-0-0
[18:18:38 891][HUB3-4][Inf]-- low_power
[18:18:38 891][HUB3-4][Inf]--Send command success
[18:18:38 891][HUB3-4][Inf]--Read command status success
[18:18:38 891][HUB3-4][Inf]-------------Download meson1.dtb-----------
[18:18:38 891][HUB3-4][Inf]--Enc(0x6c9da79f)
[18:18:38 891][HUB3-4][Inf]-- download mem dtb normal 141312
[18:18:38 891][HUB3-4][Inf]--Send download command success
[18:18:38 907][HUB3-4][Inf]--Read command status success
[18:18:38 922][HUB3-4][Inf]--Transfer complete
[18:18:38 922][HUB3-4][Inf]--Send download get_status command succeed
[18:18:38 938][HUB3-4][Inf]--get_status success
[18:18:39 456][HUB3-4][Inf]-------------ERASE FLASH-----------
[18:18:39 456][HUB3-4][Inf]--disk_initial 0
[18:18:39 456][HUB3-4][Inf]--Send command success
[18:18:39 508][HUB3-4][Err]--failed:[18:18:39 508][HUB3-4][Err]--Check command return failed
[18:18:39 508][HUB3-4][Err]--[0x32030201]Uboot/Get result/DiskInitial error
[18:18:39 508][HUB3-4][Inf]--Close device handle 0x00000a30
[18:18:52 708][Global][War]--User click stop button
Edit : About the ROM you just posted, here is the update_manual.txt file :
Ðàñïàêîâàòü soft.zip â îòäåëüíóþ ïàïêó íàïðèìåð C:\soft
Óñòàíîâèòü USB Burning Tool 2.1.7.3 (â àðõèâå)
Ïðîøèâàåì img êàê îáû÷íî ÷åðåç USB Burning Tools
íå çàáûâàåì íàæàòü Stop ïî îêîí÷àíèè ïðîøèâêè
íå ïåðåãðóæàÿ çàïóñêàåì â êîììàíäíîé ñòðîêå Windows èç ïàïêè C:\soft òàêèå êîììàíäû:
update bulkcmd fastboot
fastboot flashing unlock
fastboot flashing unlock_critical
fastboot oem reset
Ïîëüçóåìñÿ!
Do you have an english version please ? Cause I can't understand these characters. Thanks a lot !Last edited by Dicentim; 16 December 2019, 19:52.
fastboot oem reset
Ïîëüçóåìñÿ!
for rom :
Unzip soft.zip into a separate folder, for example C: \ soft Install USB Burning Tool 2.1.7.3 (archived) Flashing img as usual via USB Burning Tools Do not forget to click Stop at the end of the firmware without overloading, run the following commands in the Windows command line from the C:\ soft folder:
update bulkcmd fastboot fastboot flashing unlock fastboot flashing unlock_critical fastboot oem reset enjoyLast edited by b2oba17; 17 December 2019, 10:55.
There are currently 1962 users online. 3 members and 1959 guests.
