MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Hi natzen ,
is it possible for you to extract the rom at .zip format file ?
I don't know if you have read my story but I managed to flash the Rom once, but when I tried to reflash it a 2nd time, The usb burning tools part is OK but not way to get the box recognized by Command lines (adb or fastboot).
So I have bootloop when I try to start the box without the command lines section.
I can't understand why cause it was ok the 1st time.
Thanks for your help.
Victory!
I finally managed to flash again B2oba17's ROM.
I use a Mecool KM3 128 GB.
Good points :
Auto-frame rate works with the app pre-installed.
Netflix is OK with Zahir's 2 files. For information it didn't work on my device with the stock ROM. Now it does !
Bad points : the remote voice control doesn't work with the KM3's remote. When I push the microphone button it opens the search but doesn't hear my voice.
Someone has the voice control working?
Good points :
Good points :
I'm sorry but I have no video.
And I struggled so hard to flash it again than I won't try again.
All I can say is that :
- I flashed the ROM with USB burning tools
- I clicked on stop, I didn't disconnect the box then closed USB burning tools.
- I opened USB burning tools again to check the box is still connected, closed UBT again.
- used command lines in the "soft" repertory.
- I had the same error when I tried "update bulkcmd fastboot"
- I tried "fastboot devices" and miracle! My device appeared (that he didn't previously)
-fastboot flashing unlock
- fastboot flashing unlock_critical
- I had an error with fastboot oem reset but anyway it works.
The remote voice control issue is quite annoying.
Please also note that Netflix 3.2.2 version is quite dated and it's impossible to access the menu or search option with the KM3 remote, you'll need an air mouse for that.
There are currently 1815 users online. 0 members and 1815 guests.
