MECOOL KM3 Android Amlogic S905X2 Android 9.0 DDR4 4/64GB ROM Dual WiFi BT4.1
Originally posted by Antoyax View Post
I will try what you suggested. I'm going crazy over this. The box is perfect for me except for this Netflix problem. I will update you in a moment what happened.
However I just noticed I've a problem with the usb2. 0 port which is not defecting anything... Any other ways to check ?
Originally posted by Zahir View PostTesting this "new" firmware now.
Update:
- kernel 4.9.113, Wed March 27
- build number PI.V1.20190320
Same as before. BUT it breaks the Netflix hack and sleep is still broken. Stay away! My guess - that's all it is - is that the act of burning new firmware does something the fix doesn't like...
Antoyax - sorry your box isn't co-operating, several users here have had a similar experience. I don't have a fix. There's no earlier firmware available - the one on your box, the one posted in that link and the one on all our boxes are the same. But for some reason, some KM3s don't respond to the spoof. If uninstalling and reinstalling the two hack files doesn't sort things, maybe a factory reset is your last option. Check with others in this thread who have the same issue and consider returning your box for another - seems to be a lottery as to which ones cooperate.
btw, run DRMinfo to make sure you have Widevine L1.
Originally posted by Zahir View PostAntoyax - sorry your box isn't co-operating, several users here have had a similar experience. I don't have a fix. There's no earlier firmware available - the one on your box, the one posted in that link and the one on all our boxes are the same. But for some reason, some KM3s don't respond to the spoof. If uninstalling and reinstalling the two hack files doesn't sort things, maybe a factory reset is your last option. Check with others in this thread who have the same issue and consider returning your box for another - seems to be a lottery as to which ones cooperate.
Update:
Hello there,
I bought a new Mecool Km3 and I received today at home. So far so good I just installed all the apps I want to use and no issues found...
After a few hours using it, I was assisting a few youtube videos and the box crashed.
After that crash the box is completely unstable, I need to remove from the plug to see the blue light working again ... it crashes sometimes in the boot logo .. others crash while I'm trying to access options on the box.
I already did a hard reset and cleaned the cache and wiped the data and it's getting the same behavior.
If I turn off and wait like 5mns everything runs smooth till it crashes after a few moments.
The Firmware version is the latest one I believe 20-03 Mars is on android pie 9.
I also read something about this being a beta version yet ... so I wonder to know if I can downgrade this as well for a fully tested \ working firmware ...?
I also contacted the seller to know if he can help me with this one ...
I am looking for some help in all ways if someone in some way can give me advice on how to recover from this "bug\ crashing boots" would be great.
Thanks for your time have a great day.Last edited by meCulUSer; 03 July 2019, 12:23.
Originally posted by CcX85 View Post
Hey, I was noticing this myself and I think I may have sorted it, I used developer option and turn on keep awake when plugged in and set it to sleep when I press the power button and screen saver is set never while standby mode is active after 3 hours. For the first time this evening I pressed the power button and red light turned blue so hopefully, this helps you.
On a separate note, can I ask what you have heard about any new updates official or customer for this device cheers, are there any major flaws with the current stock Rom?
I installed the app "Wakelock Revamp - PowerManager". See: https://github.com/d4rken/wakelock-revamp
for info etc. It is available in Google Play as well.
I just enabled the Processor option and configured the app to start at boot.
I have just tested it once with success, so if someone else can confirm that it works I would be happy.
There are currently 2583 users online. 1 members and 2582 guests.
