Requests for new settings Finless 1.5
Next7P
Hi, Miklaus,
I heard you're doing good things for new flashes -- thanks, in anticipation. To help me think about your request could you describe what's possible? EG, can you extend the list of Settings?
Items off the top are: changing America/Los_Angeles to my time zone (I use New York, but there are 24 choices); and defaulting a check mark for Applications - Unknown sources (hard to see that any flasher wouldn't). Also I think defaulting USB debugging has already been done?
My N7P is labelled by the maker with s/n yf1211; but I found that Finless' #1211 ROM had no audio and many FCs; I've run Finless' #1011 both 1.3 and 1.4 without those problems. AND because of that big difference, I edited Build number to say Finless_#1011_v1.3 -- as a reminder. Forum comments say I'm not alone.
One brand new idea is open space(s) for owner use -- eg, fone or email if found by some honest soul? I did that with a text file (which is easily erased).
Thanks for you efforts on this.
RobRob / jrm
_________________
N7P rooted w/ Finless #1011V1.5 (was V1.4)
Need an option to turn off 3G, or have it completely removed from the ROM. The stock ROM has 3G built in, even though there is no way for the Nextbook 7 to connect through 3G. Another case of the maker just slapping a ROM on a cheap device it isn't optimized for. Anyway, the Nextbook burns a lot of battery juice searching out a 3G connection. I use a 3rd party battery app to stop this, but it would be nice if that app wasn't needed.
Originally posted by ZonaMojo View PostNeed an option to turn off 3G, or have it completely removed from the ROM. The stock ROM has 3G built in, even though there is no way for the Nextbook 7 to connect through 3G. Another case of the maker just slapping a ROM on a cheap device it isn't optimized for. Anyway, the Nextbook burns a lot of battery juice searching out a 3G connection. I use a 3rd party battery app to stop this, but it would be nice if that app wasn't needed.
@ZonaMojo, Which apk "stops" 3g search? Do they say in blurbs about amps running 3g hardware vs amps running software?Rob / jrm
_________________
You can't remove the phone.apk. It at worst has caused my tablet to boot loop, and at best causes other apps to crash. I use Battery Doctor to turn 3G off. I don't recall which app I used to check battery usuage, since I uninstalled it once I realized it offered no way to turn off 3G. It did show active radio signals searhing for a 3G.
Sent from NB7 Finless 1.4 via Tapatalk
There are currently 3819 users online. 0 members and 3819 guests.
