X96Max_V311:the latest firmware
    Originally posted by cobbin View Post
    Hi jiangsai0703, thanks for your great works! Does that work on x96 max u211 (4g/64g) devices?
    Yes, It supports 4GB versions
      Originally posted by uscool View Post
      one for 2/16 version ?
      This firmware is suitable for 4GB
        Thanks! It works well on my x96 max 4g/64g device.
          Okay, thanks. Flashed in my 4G box. Everyone is working good, but play market don't want install many app and kodi too
            I was also waiting for 2 gb version, is this official build or have the OP compiled using Amlogic SDK? jiangsai0703
              I'll update the 2G version soon. Please wait for me.
                Good to know that you are able to compile Android 9 rom.
                Also, i would suggest that you should change the title to Android 9 ROM so that more people can clearly understand.
                Thank you so much for the efforts.
                  AndroidP ATV_X96Max_V311_4GB_Ram_Firmware.img -
                  I also waited for the ATV version
                    Has anyone tried this firmware on 2gb model? besides bluetooth, is there any issue? I wonder the wifi will work in this firmware or not?
                    Everyone with 2gb model reading this should also note that this is android pie and developer is working on 2gb model also.
                      I have WIFI issue on 2/16 model , WIFI randomly can stop working after 20mins or 10hrs and box needs restarting to work again wonder if its fixed with Android 9
                        Hi jiangsai0703
                        I know asking for ETA is bad but is there any update for 2/16 users if you dont mind?
                          Hi jiangsai0703
                          I'm sorry, I have finished the firmware of X96MAX 2+16, but I haven't uploaded it successfully because the network can't connect.
                            X96MAX 2+16 :
                            Finally, I found a disk that can be uploaded.
                              https://yadi.sk/d/jpWPfum6SC9EBw
                              X96MAX 2+16 :
                              Android P- Yes
                                X96MAX 2+16 :
                                Hi, just tried it the WIFI doesnt work
