[ROM] POISONATV S905X NEW V4 [20190317] *UPDATED NEW VERSION 4.2*
Originally posted by minixfreak View Postalright guys neomode will update the p0ost later , but here are the links for v4.5 .... i never did a changelog but it should be stable with no bugs
https://mega.nz/#F!A8BihSCb!EA2vnBM6sqVX8BYll-W_PA
Thank's for the update, but I can't get play store to work in this version either. It says there's no internet connection, but tested it in Speed test and got 100mbit down.
Tested on Mini m8s ii
Seems sluggish and getting stuttering on video playback. Gone back to redpoison V2 which runs quick and smooth.
For some reason redpoison V2 seem to be the only version that runs quick and smooth on my box.
Did have a slight problem when i installed redpoison V2, that also seemed sluggish. I installed it for a second time and now it runs fine.
Wondering if its worth trying to install v4.5 again and burning it twice to see if makes any difference.
Cheers Mate
By far, Poison ATV v4.5 is the best ATV firmware ROM yet on my Tanix TX3 Max. The video and audio quality is outstanding. Seems like I'm running a TV box in the $100+ range. As minixfreak has stated make sure to "Erase All" in the USB Burning Tool interface or you will have issues. I made that mistake myself. I used USB Burning Tool v2.1.6.8 and it went smooth as butter. Huge thanks to all the devs and I look forward to using future releases. BTW Every app works excellent in v4.5 and you have successfully squashed the hard lockup on audio bug from the original Tanix firmware.Last edited by NocturnalE; 12 April 2019, 15:17.
Hi there I'm looking to update my friends Probox2 Air running android 6
been a while since there was an update but with your Rom, I'm able to update to something more stunning as its soc is s905x
unfortunately, I've not brought my USB cable to do the update with USB burning tool, would it be okay to use the
SD Card method and if so what is the best software to use.
thanks for the great work
Installed version 4.5 on Nexbox A95X 2G/16G box. I see following issues:
1) Home screen recommendations don't work for any other downloaded app like youtube or haystack TV. They used to work great in V2. The recommendations only work for Google movies for some reason.
Update: Some apps are working fine like youtube and HaystackTV. However, Plex is still not working Not sure why.
2) Nexbox remote stopped working, it used to work great in V2. I am able to use an airmouse in the interim. Hopefully someone will be able to let me know how to install the Nexbox remote patch.
3) Google playstore works fine, so no issues there.
I will keep 4.5 for now and wait for next update.
Originally posted by hannah View Post
Please update this download link as the folder is no longer available.
Originally posted by huffmybrd View Post
My tv box is :
Docooler M9S-PRO S905X 2GB/16GB (it's a fake 2gb, actually the box has 1gb)
PCB Board:Model Number: H234_V2.08 2017-01-20
# begin build properties
# autogenerated by buildinfo
ro.build.display.id=hx_s905x-userdebug 7.1.2 NHG47L 20171030 test-keys
ro.build.version.release=7.1.2
ro.build.version.security_patch=2017-05-05
ro.product.model=hx_s905x
ro.product.brand=Amlogic
ro.product.name=hx_s905x
ro.product.board=p212
ro.product.manufacturer=HongXin
ro.board.platform=gxl
Many thanks
Hi All,
Do we know the reason why these links keep become invalid.
e.g: https://mega.nz/#F!ItZSWQiJ!kRP7BQpKjAOXSIo0oXN11w
There are currently 2307 users online. 1 members and 2306 guests.
