[ROM] POISONATV S905X NEW V4 [20190317] *UPDATED NEW VERSION 4.2*
Originally posted by canadien View Post
Originally posted by DrDroid View Post
https://forum.freaktab.com/forum/tv-...230#post788230
That link is for the S905W and that ROM is based on. Android TV with a lean back launcher, I am looking for this ROM for the S905X based TV Box SoCLast edited by canadien; 06 November 2019, 16:13.
Originally posted by claishem View Posthi. im sorry if this is out of topic but i just cant get an answer from anyone here in other threads. i hope someone can answer me here. why does ADB DOESN'T WORK on x96 mini STOCK FIRMWARES? but with other firmwares for s905w that i have installed on my x96 mini ADB works.
canadien yes sir. even of i turn it off and turn it on again there is no response in the pc. the device is not being detected in the device manager. even enabling the MTP mode in usb options, the pc doesnt recognize the device as usb storage. tried it with stock 7 and 9 firmwares, not working.
Ps perhaps you can go on using wifi adb...?
Sorry then. 2 last things: test with all usb port, if it's like flashing rom, there is only one that works. You can also try adb in twrp recovery, perhaps it will work better. If not, then change your usb cable or try another rom. In anycase I am an eternal newb so can help you much, unfortunately.
with regards to adb via wifi you will still have to connect the device first via usb to establish the adb connection so that wont be an option.
with any other roms that i flashed in this x96 mini device i have had no problem with adb. only with the stock firmwares that adb doesnt work. that is why i am using the tx3 mini stock firmware now.
Dear folks, managed to get ATV9 booting up on x96W+...for most devices only ethernet supported due to missing wifi drivers.. V1 without wifi V2 with wifi and bluetooth support for TX3 Max, TX3mini and x96w+ RT8723bs due to changed source! Some wifi could be missing Big thanks sagert for pointing me to UR TOOLS. Why this?
or flash stock Android 9 regular for x96 mini
Hi, I flashed this rom S905X in this tv box, and everything works perfect, except the mouse cursor, I am with the remote control and the hand (cursor) appears at every moment and does not disappear or unplugging the mouse ... will it have a solution? , thanks.
EDIT: I flashed the patch of the remote and it works fine.
You may only view thumbnails in this gallery. This gallery has 3 photos.3 PhotosLast edited by joseac; 07 January 2020, 22:10.
I flashed this one too and it works fine too, Zenopllige Z11 Pro
https://www.amazon.es/Zenopllige-And.../dp/B01MF8VULH
There are currently 4868 users online. 0 members and 4868 guests.
