[ROM] POISONATV S905W NEW V4 [20190317] *UPDATED VERSION 4.2*
Guest
thank you very much sir Guest .
and one more thing sir, how do i change the boot animation? i already unpacked the firmware using customization tool, replaced the bootanimation.zip in system media folder, and even changed the content of bootanimation folder in Level 3 folder, repacked the firmware, flashed in burning tool with erase all option. but upon boot the bootanimation does not change. thank you very much.
Originally posted by jebjeb View Post
Thanks. Do you have the x96mini? Which roms have you tried so far and which one you like the best?
ive tried atv experience which was good but little old, then I tried poison which was great but my original remote didn't work, so now using the one for 905w from the few posts above. Everything works, just the purple colour needs changing! ATV was white, posion was solid red and this is pinkish purple!
I had problems installing using the usb cable burning tool. Had to open the box and short circuit a chip, easy as chips, just use a paper clip touching the metal of the hdmi cable port and the specific location chip. Only usb inserted only!. Then after instead the power before flashing, hope this procedure makes sense
Originally posted by alessa View Posthello ,i have a x96 mini and have 2 questions:
1 .with this rom the wifi work or dont work?
2. the RC works good?
thanks.
If you use the links in this post, the WiFi works fine and the remote is working fine also
AndroidTV Project ChangeLog -Based Off My PoisonATV Versions -Improved stability and performance -Brand New Look -New Tweaks -Amazing Video Quality -First Boot might be a bit sluggish due to my new tweaks but after apps update and tweaks are done running you can do a reboot and second boot will be fast and pleasant... -Always
Hope this helps
There are currently 2309 users online. 0 members and 2309 guests.
