X96 MAX:HDMI problem after flash with usb burning tool
    hello .
    I have a problem after flashing this rom.
    I flash the rom via usb burning tool.
    but at the moment to remove the bootloader, the box is disconnected from the pc and so there was an error message.
    since, I have no more signal on the hdmi of my television!
    I managed to flash the rom again but nothing to do, still no hdmi signal.
    Do you have a solution?
    EDIT: i have flashed a stock firmware and the CVBS (av) signal work but the hdmi dont work animore!
    I too have the same problem with my t95q it was working fine and after I flashed stock firmware I too don't get any HDMI signal . I hope some one can help
      I read that some people have had the same concern about 4PDA, but I do not know if they have a solution ...
        I tried registering in 4pda but it's a Russian forum and can't register hopefully someone from here can help
          search in this thread ,just traduct via google traduction . https://4pda.ru/forum/index.php?showtopic=925461&st=20
          I will probably have to read every 630 pages ... to both of us it will be more effective.
            I found this thread it may help you I tried this in my t95q but it didn't help but yours is a same box so give it a try
              https://forum.freaktab.com/forum/tv-...-0-bt4-0/page8
              Thank you I test that as soon as I come back from work. but I think it will not solve anything, my problem is different.
              I connect an av cable and the image works, it is via the hdmi that it does not work ...
              Do you have a technique to register on the Russian forum 4pda? Thank you.
                Did you solve your issue?
                  No.
                  the hdmi entry is broken. I got a refund and I took a beelink gt1 mini​​​​​​
                    Originally posted by alessa View Post
                    No.
                    Do you mean your port was faulty did you try to resolder it ? I am thinking of buying gt1 too did you get the box from where did you purchase ?
                      Yes it is defectiveI can not find anyone who can sold me the HDMI output. I bought the gt1mini on amazon.
                        No.
                        Did you get video from av output?
                          Yes
                            Yes
                            Mine has no video output from both av and hdmi
