I can't get to work Static IP on Ethernet connection on my Tanix TX5 max with stock firmware (2019-02-21)
It's not configuration of the router because it works on a TX3 mini and a H96 Pro +
While searching in forums i came across someone with a T95Q that also has the same problem.
Does anyone know if this is a Android 8 and S905x2 devices problem or are there other brands that have Ethernet Static IP working?
I would like to know if anybody has the same problem or does it work in some diferent brands like the X96 Max ; Beelink GT1 mini ; H96 Max X2 ; T95Q ; KM9 ; MXQ G12...etc...
Thanks in advance
