Beelink GTKing Amlogic S922X 4/64GB Dual AC WiFi-MIMI GiG Lan BT4.2
Due to the Magic of Fast Couriers (DHL), I present for your Viewing Pleasure:
Box and what's in the box
https://i.imgur.com/QhZQW6L.png
https://i.imgur.com/tKiUqab.png
Remove base more goodies
https://i.imgur.com/ETHYyVM.png
Out with PCB lots of Goodies
well I'm not insist such as Ugoos should be,so Beelink King model and Odroid the remain two nominees!
Or might be other Boxes will release?
I need a new Box,my last Box was A95X MAX,but its not impressed me,"picture quality" doesnt satisfy me
and way far from RK3399!
RK3399 very good&best for this area but all those RK3399 boxes problematic especially with Firmwares
and after a while they do not release any firmware and they forget those boxes++
Hi ,
i am not the only Ugoos Owner , that is now dissapointed from there support, the Boxes are not bad , but not
really good support , here , hope you find what you need , Antutu Score is only 10000 more , a good Dev. we
well I actually need/request RK3399 only! but I'v been bought 3 different brand RK3399(X99/H96/N6) all are really disappointed
and worst one is N6
Than I'v bought S905X2(A95X MAX) its such a good Box and it has OTA! we still do not know is the real manufacturer! Mystery Box
so this Box O.K but "picture quality" not better or not better than RK3399!!
RK3399 Picture Quality
I do not know how this new S922X "on paper and pre-reviews" seems that this Box very good,so we will see whats happen in near future
RK3399 devices like Khadas Edge and Radxa Rock Pi 4 are very good.
If you buy all the separate items, you can use it as a tv box.
Android Pie already released for them or soon and they are open-source.
Linux and LibreELEC also well supported.
I'm also going to make a custom Android Pie firmware for Khadas Edge RK3399 soon.
S922, the only device that will get updates are the Ugoos one I think, the Beelink one will stop getting updates after 2 months like always and will have worse support than RK3399.
Advertised features like Dolby Vision, HDR, Amazon Prime Video etc. not even working.
S922 also runs in 32-bit mode while RK3399 firmwares run in 64-bit mode.
Wir stellen vor: Radxa: Entfesseln Sie Ihre Kreativität mit kompakter Leistung! Radxa definiert mit seinem ultrakleinen Formfaktor und seiner kompromisslosen Leistung die Möglichkeiten des Single Board Computing neu. Egal, ob Sie...
Model B, 2GB RAM Essential - Then you must also purchase EMMC 16GB + EMMC to micro-sd card adapter
Hi, Nice work But I have a problem with the play store, on a fresh installation it makes 2 update and then are 4 updates waiting but nothing happens. In meanwhile I uninstalled this 2 updates and Noel are 5 updates waiting. Is it no possible to installed something new. What could I do? Greetings
Odroid N2 + all accessories also costs about Euro 140-160 since you need to pay extra shipping and taxes too.
