Beelink GTKing Amlogic S922X 4/64GB Dual AC WiFi-MIMI GiG Lan BT4.2
well I wanna to buy from Gearbest or Geekbuying
Aliexpress in my "Black list"
therefore seems that its "pricey"
Note;and I need "REVIEW" from Freaktab Forum masters instead of FAKE Gearbest&Geekbuying customer reviews!!!
Bye++
At present "price doesnt matter"
1-Firmware?? is it stable etc.,!!
2-OTA and other supports??
those are then more important!
So expectations are always high! but than everytime just a disappointment
"as usual"
So,we have to see/check/use etc., for "final" act
By the way in frankly if the price around $ 120/130 then its pricey!
"as usual"
look Post #15 , it is already available on Ali..... ,
greetings / gefatternLast edited by gefattern; 01 May 2019, 16:50.
I think I will wait until Mecool comes out with there version of boxes with the Amlogic S922X SoC. They are getting closer to providing a Google Certified box that actually works as a media player.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Looks like Geekbuying is playing it first
Beelink GT-King Amlogic S922X Android 9.0 4GB DDR4 64GB eMMC 4K TV Box with 2.4G Voice Remote Dual Band WiFi Gigabit LAN Bluetooth USB3.0
Specification$115.99 after coupon: FJKSUUMQGeneral Brand: Beelink
Model: GT-King
Type: TV BoxHardware OS: Android 9.0
CPU: S922X Quad-core ARM Cortex-A73 and Dual-core ARM Cortex-A53
GPU: Hexa-core ARM G52 MP6 Graphics
RAM: 4GB DDR4
ROM: 64GB eMMCCommunication WiFi: 2.4G/ 5G WiFi
LAN: 1000M
Bluetooth 4.1Video Amlogic Video Engine (AVE) with dedicated hardware decoders and encoders
Support multi-video decoder up to 4Kx2K@60fps+1x1080P@60fps
Supports multiple ?secured? video decoding sessions and simultaneous decoding and encoding
H.265/HEVC Main/Main10 profile @ level 5.1 High-tier; up to 4Kx2K @ 60fps
VP9 Profile-2 up to 4Kx2K@60fps
H.265 HEVC [email protected] up to 4Kx2K@60f
AVS2-P2 Profile up to 4Kx2K@60fps
H.264 AVC [email protected] up to 4Kx2K@30fps
H.264 MVC up to 1080P@60fps
MPEG-4 ASP@L5 up to 1080P@60fps (ISO-14496)
WMV/VC-1 SP/MP/AP up to 1080P@60fps
AVS-P16(AVS+) /AVS-P2 JiZhun Profile up to 1080P@60fps
MPEG-2 MP/HL up to 1080P@60fps (ISO-13818)
MPEG-1 MP/HL up to 1080P@60fps (ISO-11172)
RealVideo 8/9/10 up to 1080P@60fpsDisplay HDMI 2.1 output up to 4K@75Hz
HDMI 3D video formats
HDMI HDCP 2.2
AV(CVBS) 480i/576iInterface USB3.0, USB2.0, HDMI, LAN, AV jack, SD card slot, DC in, SPDIF Power Power Type: External Power Adapter Mode
12V-1.5A 18W Certification
Input: 100-240V~50/60Hz , Output: 12V 1.5ADimensions&Weight Product size: 10.8 x 10.8 x 1.53 cm / 4.25 x 4.25 x 0.60 inches
Product weight: 190g
Package size (L x W x H): 13.5 x 15.4 x 7.5 cm / 5.31 x 6.06 x 2.95 inchesPackage Contents 1 x TV Box
1 x 2.4G Voice Control
1 x Power Adapter
1 X HDMI Cable
1 X User Manual
Geekbuying
GearbestLast edited by trebor; 06 May 2019, 05:10.
Greetings Trebor, thanks for the info.
Have a few questions and appreciate if anyone can enlighten:
1. Is the 922x chipset the first to support HLG?
2. Any info on Dolby Vision support?
3. Does the built-in media player support external audio track? If not, any one you would recommend? (I don't think kodi does it, am I right?)
4. Does it support external aas and sup subtitle?
Many thanks and best regards,Last edited by goop; 05 May 2019, 08:56.
Thank for kind reply.
So kodi support loading external audio track, and external aas and sup subtitles?
Can it do so when reading an ISO file or BDMV folder?
Also, I was under the impression kodi has stopped supporting new amlogic processors?
Originally posted by bergamesk View Postwell I wanna to buy from Gearbest or Geekbuying
$ 119
I do not like it this price!!
I do not rush and I'll wait couple of days,especially wanna to see and check UGOOS price too
We knew it such as "RK3399" price and performance! even this Box pricey too! and definitely not wort
against of their problematic "firmwares"!
And who knows S922X firmware performance and stability!
Before I got GT1 Ultimate(last year) worst FW,very bad InternetSpeed(WiFi&Ethernet) and lot of BUGs too!
I do not trust Beelink Co.
But if Freaktab masters give us approval then sure its OK!!
"AML" 9xx ...... and 922 is not RK3399! and they offer $ 115/120
W'v to think about this!!
There are currently 4045 users online. 0 members and 4045 guests.
