TWRP Recovery 3.2.3 flashable for S905x2/ u211 devices
    TWRP 3.2.3.1(Android 8.1) Recovery can be found here:
    https://forum.freaktab.com/forum/tv-...943#post758943
    (Made by Magendanz post #1518.1)
    or here: https://1drv.ms/u/s!AoqocX31ecnXgbIdSaKxLK3e-SPboA
    a.[HowTo] install TWRP zip-file:
    1. install "Recovery reboot app" (google playstore)
    https://play.google.com/store/apps/d...eboot&hl=en_US
    2. open app and reboot to recovery.
    3. in recovery choose "Apply update from EXT",
    choose sd-card and ur TWRP-u211-3.2.3.zip file.
    4. install
    5. reboot....done...
    b. [HowTo] install TWRP img-file:
    1. install Amlogic flasher
    2. open app, choose .img recovery and flash!
    (img file must be in root of internal storage)
    Now reboot to twrp recovery and do a backup first
    before u install any other firmware or rom!
    android 9 TWRP ->
    https://drive.google.com/file/d/1D-R...ew?usp=sharing
    if u wanna flash back to
    Stock recovery for S905x2 ->
    https://mega.nz/#!2mZmlADL!dkKVceGi1...g7dX40E2QmUuMk
    (just install with twrp....)
    hello.
    this work on the xtrom atv ?
      Originally posted by alessa View Post
      hello.
      just give it a try and report...
        its work ;-)
          Bug: No partition can be selected for backup.
          x96 max 4/32 xtrom atv v3
            TWRP Recovery can be found here:
            [HowTo] install TWRP:
            4. install
            No partition to select for backup appears.
              Thanks for the instructions.
              I followed them on my X96 Max 4/64GB
              All went good, only thing i was not sure about was after the 5 steps you said
              "Now reboot to twrp recovery and do a backup first
              before u install any other firmware or rom!"
              Well when i rebooted to TRWP recovery, i was asked to mod my partition as it was read only.
              i did not know what to chose so i let it mod the partition i assume for write permissions.
              I hope that was the correct thing to do and if not should i change it back?
              Then i did the backup, i assumed it would write to the sdcard but it defaulted to the internal storage.
              Next time i will try and change that to the sdcard.
                You have done all correctly, and on the next backup
                just choose"select storage " at the left lower side corner...
                  How to enter recovery mode from a cold boot? I'm stuck after boot animation so I can't get into reboot to recovery app.
                  Edit: i can enter recovery mode, factory reset, but still stuck after boot animation. My box is hk1 play, board u213 in configuration
                    4. install
                    android 9 TWRP ->
                    So this is 2 ways of doing it or you have to do first A and then B?
                    i got a X96 max.
                    thanks
                      i got a X96 max.
                      thanks
                      Yeah, 2 ways of doing it.
                        When I try with reboot and trough SD I get error 21.
                        when I do with amlogic flasher I open the app and go to img. I can’t see or select any img files...
                        It’s a X96 Max 4GB/32GB with Android 9.0 pie stock.
                          img file must be in root of internal storage 4 amlogic flasher.
                            Works thanks!!
                              4. install
                              android 9 TWRP ->
                              i did step A.
                              3)after i chose sd-card...it stated its empty.
                              in the working mode...i am able to see my sd-card card with the image file.
