which air mouse / keyboard to buy?
Thanks for the reply but I think im gonna go with the iPazzport since it cost way less then the other remotes and the ones you mentioned. But before I buy mine just wanted to confirm one more thing is there any lag issues with the iPazzport and does it work good with XBMC? also since you have the remote is there any reason you think I shouldnt buy one or why you would recommend the other two remote.
Originally posted by diegocaxudo View Post
I bought the Logitech K400 keyboard/mouse combo. It works beautifully on the Minix X7, no setup required. It detected it almost immediately, and works great on all apps. XBMC however gets some hiccups when using the keyboard, but only on screens where I'm typing in a web address or manually adding a directory.
Thanks for the reply. I was looking for something portable or small.
Originally posted by aniym View PostI bought the Logitech K400 keyboard/mouse combo. It works beautifully on the Minix X7, no setup required. It detected it almost immediately, and works great on all apps. XBMC however gets some hiccups when using the keyboard, but only on screens where I'm typing in a web address or manually adding a directory.
Originally posted by alikhan2004 View PostThanks for the reply but I think im gonna go with the iPazzport since it cost way less then the other remotes and the ones you mentioned. But before I buy mine just wanted to confirm one more thing is there any lag issues with the iPazzport and does it work good with XBMC? also since you have the remote is there any reason you think I shouldnt buy one or why you would recommend the other two remote."Success is a lousy teacher. It seduces smart people into thinking they can't lose."
- Bill gates
Originally posted by diegocaxudo View Postthere is something I hate about the remote, I didn't tought about it at first but, when I'm not using the keyboard (I'm using the mouse), I allways need to switch back to the "keyboard mode" (Landscape) if I want to use the arrow keys (for the xbmc or anything els) or if I want to use any function key (home, back, play-pause...). With the Rii k25 you have all the buttons you need in the remote side, you only use the keyboard when you want to write something.
Originally posted by diegocaxudo View PostWith the Rii k25 you have all the buttons you need in the remote side, you only use the keyboard when you want to write something.
Is this typical of most IR/keyboard remotes? (I'm new to this whole TV box thing - I'm sick of using my PS3 to stream content on my LAN).
Originally posted by Scratchpad View PostI ordered the RII K25 from geekbuying when I ordered my X7 (it only just shipped so I won't get them for a couple of weeks yet). I recently saw a video review of the RII K25 that said the remote side doesn't work with XBMC because it uses IR only (doesn't communicate with the USB dongle) and so does not generate keyboard presses (the keyboard side uses the dongle and obviously generates key presses).
I ended up not buying an ir remote so I cant say for sure that this is correct info, but thats how it looks to me
Originally posted by alikhan2004 View PostI actaully ordered mine from newegg.com but it turns out the seller is geekbuying on newegg also so I need to wait a couple weeks also because the remote is being shipped from China so I'm still waiting for my remote to come in also but once I get it I'll let you know how it turns out.
Originally posted by netghoster View PostAny Update on the RII K25? Thank you
Just a quick word on the A2. Lots of people have had issues with battery life but it's been fine for me, so some units may have an issue I guess. Re the auto repeat, you can get apps (eg External Keyboard Helper) which should allow you to turn auto repeat off. I find the the range OK for what it's worth.
There are currently 1632 users online. 0 members and 1632 guests.
