Does anyone know where I can set a copy of a factory image for the box with all the apps it originally had? Really need Netflix - and can't source a working version.
H96 MAX RK3318 Android 9.0
I updated my box using the latest firmware on https://www.h96tvbox.com/content/6-Firmware-upgrade using the USB Key method, and the image doesn't contain any of factory installed apps, and wipes all the apps that are currently installed.
Originally posted by silver2k View PostI updated my box using the latest firmware on https://www.h96tvbox.com/content/6-Firmware-upgrade using the USB Key method, and the image doesn't contain any of factory installed apps, and wipes all the apps that are currently installed.
Follow this guide to flash properly ... a short demo video ...https://drive.google.com/drive/folde...x-qPB4CWC8FFbQ
Originally posted by robricc07 View PostSomebody can help me? I cannot found the Hard reset button on this Android Box and how it's possible step by step to install to right firmware?
Please answer me also with some photo, i am not so able in this
Thank you for all
Roberto
Hello,
Try several times flash the box using the USB method. Try more than one Pen.
No luck ... firmware update stuck on the boot forever! Wait 10, 20 and 30 minutes...no update.
After reboot system advert about the failed firmware operation.
Also the steps are not the same that are published in H96 website ...
So since in the essential the box works for me I'll stop try the flash.
What I woulkd like to do was change the native launcher (Mediabox) to anything better
And more open but system refuse anytime I try claim with a parsing error...
Anyone have success change the launcher ? If so witch one ?
Thanks a lot for all by sharing your experiences and knowlege here.
Cheers
Cheers
The problem of this tv box is that the loader is locked, that's why you can't update the firmware.
To recognize the pc you must make the following bridge.
If the information served you please made 1 USD on paypal [email protected] Thank you.
Originally posted by mo123 View PostI would suggest users stay away from RK3318 devices.
It is a low cost version of RK3328 only sold to 2 or 3 companies by Rockchip, making cheap tv boxes.
The CPU only runs at 1.1Ghz, not 1.5Ghz like RK3328 and corners are cut everywhere to bring the cost down to compete in price with Allwinner H6.
Don't expect any firmware updates or such devices to still work after 3-4 months because of the low quality RAM and emmc chips used.
When I saw the crappy emmc,it took me by no surprise at all about the SD test,the speed couldn't handle 4K videos....1.1Ghz,wow...low price competition.
Kia Ora - wifi connection
Bought one of these boxes and couldn?t get my iptv to work. I updated the firmware (I think) and now I can?t pick up any wifi connections.
Would anyone know a solution to get the box to detect wifi connection again.
I have restarted the box a number of times.
Cheers
Hey guys. Can anyone help me here. My box just stopped working last night. I'm new to all this android box stuff. So from what I can understand I think my box is bricked red light on the box. But wont power on. I tried the reset button by av. And notting I tried the frimware up date it connected to my laptop and said upgrade successful. But still cant boot the box. I'm not sure why the box went like this. Few days ago I nottice all my apps where gone off home screen and found it strange as I didnt change anything. Would appreciate any help
Cheers
This ROM is based on the no-root Rom from https://www.h96tvbox.com/content/6-Firmware-upgrade. As su was still around in their no-root image (!) I was not able to run TV-GO from Hungarian Telekom as it needs a fully unrooted system. So I have also fixed this by fully removing su/root in this modified ROM.
Also incuded instructions and tools in the zip to unpack, modify and repack the ROM to taylor it to your needs. Enjoy!
Guest
Hello all...
My H96 Max 4K UHD RK 3318, 4GB ROM, 16GB RAM, Android 9 is dead.
After connecting the power supply, the display shows 'boot', but the tv screen is black. After 60 seconds the 'boot' disappears and inside the H96 the red LED lights ...
I have access to https://www.h96tvbox.com/content/6-Firmware-upgrade.
How to prepare a USB flash drive and fix my H96 with use this method?
Regards, Piotr.Last edited by Guest; 30 September 2019, 12:37.
There are currently 1783 users online. 1 members and 1782 guests.
