H96 MAX RK3318 Android 9.0
    23:02:57 291 Layer<12,2-1-2>ownload Boot Start
    23:03:00 392 Layer<12,2-1-2>ownload Boot Success
    23:03:00 392 Layer<12,2-1-2>:Wait For Maskrom Start
    23:03:00 860 Layer<12,2-1-2>:Wait For Maskrom Success
    23:03:00 876 Layer<12,2-1-2>:Test Device Start
    23:03:00 876 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
    23:03:06 406 INFO:RKU_ResetPipe-->DeviceIoControl OK
    23:03:06 406 Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0
    23:03:06 422 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_320C#6&178D9F8D&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:03:07 431 Error:RKU_Open-->CreateFile failed,err=3,path=\\?\USB#VID_2207&PID_320C#6&178D 9F8D&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:03:07 431 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320C#6&178D9F8D&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:03:08 445 Error:RKU_Open-->CreateFile failed,err=3,path=\\?\USB#VID_2207&PID_320C#6&178D 9F8D&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:03:08 445 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320C#6&178D9F8D&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:03:09 459 [Error] Layer<12,2-1-2>:Test Device Fail
    23:29:41 294 Layer<12,2-1-2>ownload Boot Start
    23:29:44 508 Layer<12,2-1-2>ownload Boot Success
    23:29:44 509 Layer<12,2-1-2>:Wait For Maskrom Start
    23:29:44 961 Layer<12,2-1-2>:Wait For Maskrom Success
    23:29:44 977 Layer<12,2-1-2>:Test Device Start
    23:29:44 977 Error:RKU_Write-->WriteFile failed,bRet=0,err=31,size=31,write=0
    23:29:50 513 INFO:RKU_ResetPipe-->DeviceIoControl OK
    23:29:50 528 Error:RKU_Write-->WriteFile failed,bRet=0,err=995,size=31,write=0
    23:29:50 528 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-3),path=\\?\USB#VID_2207&PID_320C#6&178D9F8D&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:29:51 533 Error:RKU_Open-->CreateFile failed,err=3,path=\\?\USB#VID_2207&PID_320C#6&178D 9F8D&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:29:51 533 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320C#6&178D9F8D&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:29:52 536 Error:RKU_Open-->CreateFile failed,err=3,path=\\?\USB#VID_2207&PID_320C#6&178D 9F8D&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:29:52 536 <LAYER 2-1-2> ERROR:TestDevice-->RKU_TestDeviceReady failed,RetCode(-1),path=\\?\USB#VID_2207&PID_320C#6&178D9F8D&0&2#{ a5dcbf10-6530-11d2-901f-00c04fb951ed}
    23:29:53 550 [Error] Layer<12,2-1-2>:Test Device Fail
      thanks, same problem here, but it is factory tool 1.6 and mine is 1.64, so it's the newest oneClick image for larger version
        When you make the bridge to enter maskrom once recognized remove it?
          i'm not sure if i understand your question but, as i said earlier:
          "the main problem seems to by while in test device mode, pc disconnects for a second every time, and stops the process.
          I don't think it's a software problem, rather hardware failure."
            When the device is blocked Red LED to enter recovery the bridge is made that I see that you have done it once the PC has recognized it is no longer needed, the bridge is removed.
              The latest driver update is 4.8
                i hope the video will help you understand whats the problem, at 18 second the device disconnects itself for a second and thats when the process stops
                  Be sure to flash the correct firmware !
                  there seems to be two variants of this box with
                  different WiFi chips LTM8830 And AP62255
                  Is it possible you could msg the seller and ask for the
                  Firmware it saved me alot time and effort.
                  If not you need to identify your WiFi chip and the correct firmware. If your unsure on Ur WiFi chip there's apps on Google
                  play store that can tell you.
                    I did manage to succesful instal the image, but the red led is still on, i do think islis a hardware issue. I didnt find any other img for the RK3318.
                    You may be right about wrong software but i can't find any other to test it anyway.
                    I've used the one from here https://www.h96tvbox.com/content/6-Firmware-upgrade
                      Have you tried this firmware and tools?
                      i flashed and updated my h96 max using
                      That firmware and drivers and flash tool.
                        yup, i 've tried this one, still RED LED on board.
                        as i understand you have updated your box, but it was working fine before the update?
                        my problem was that the box bricked by itself, and was only flashing with RED LED, no blue LED at all. So it seems a hardware problem.
                        Did you have RED LED on your board?
                          No I didn't I just had few issue with 4k YouTube streaming.
                          if my box had the same failure as yours I would message the seller there the ones who can help more than anybody else.
                          If your box is faulty just return it.
                            Ive contacted the seller, they suggested to send it back bit i need to cover the shipping costs which are about half the box is worth, so thats why wanted to fix it myself.
                            probably ill just return it.
                              I buy my electronics from Amazon so if I have issue I will get full refund and told just to bin the product, the problem I found
                              with buying these android box's your taking a gamble but I gotta say this box is a brilliant device and I got for 35£ that's
                              a fantastic deal 4gb 32gb storage quad core and on Android 9.0 them specs are more and 60£ ± range. I did have few issues with firmware but I corrected that by messaging the seller and explained the issues , box I have is the exact one on first page of this topic and from what I read and seen the box's had a mass rushed factory firmware and what I got from my seller was the last final firmware for this box and I say final
                              Because there is zero issues with it and corrects any issues I found.
                              Any who hope you fix your problem.
                                I try to install with TWRP this ATV9 system backup
                                But bootloop, if somebody can help
                                i reinstalled last rom (14-11-2019) https://www.filefactory.com/file/6mj...91114_v002.zip
                                with Android tool 2.71 (link with rockchip tools) https://github.com/rockchip-linux/to...master/windows
                                No problem for erase and upgrade
