All help would be sincerely appreciated. Thanks!!
Help with recovery button S90X M9C Pro
I cant turn on the box as it is stuck on red led. It won?t go blue. In order to flash another ROMs I need to get the device in recovery mode and I cant find it. There isn?t one under AV port.
All help would be sincerely appreciated. Thanks!!You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by iamsushantsharma; 18 May 2019, 14:13. -
Originally posted by iamsushantsharma View PostI cant turn on the box as it is stuck on red led. It won?t go blue. In order to flash another ROMs I need to get the device in recovery mode and I cant find it. There isn?t one under AV port.
i already answer in the other Thread , no chance to recover this way you must flash new / Stockrom
or any really KNOWN compatible Rom , maybe ATVExperience for your SOC , but what ever you want
to do , ALWAYS ask in the specific Thread for Info & help .
greetings / gefattern
Originally posted by iamsushantsharma View PostI totally understand that I need to flash a new rom but the issue here is that how can I flash without the recovery mode. Is there a way because I don?t have any button for recovery mode.
Thanks.
what , you can flash any / .img / Rom that fits with your Box ,
with your PC , no need to use Recovery , nobody does it this
Way , not really good supported with CWM only with TWRP
it is possible but for this you need the right TWRP and the
right /.zip / to flash , do it with PC , best Way ,
Okay, I think I was unable to explain clearly
I have been trying to flash via USB Burning Tool and not any custom recovery,
unfortunately my device won't get recognised.
In youtube tutorials where they ask to press the recovery button with a toothpick, I don't have that button or infact any button on my box.
I am so troubled
Hi ,
so if you really have no Button for Recovery you must "shortPins" to get your Box
recogniced by PC , this are two Pins on the NandChip , if old solder method is used
and you can see the Pins beside the Nand , if not u must for sure "short" some other
Points on your Board , to get it back to life , you can find many Infos about "shortPins"
so called "MASKROMMODE" , here on FT or online , hope you get it back to life ,
Hi again ,
not sure but i think you can use the two round Points in front
of the solder Row (build date on the left side) , to short Pins ,
some PCBs have the extra Points near Nand , for that , but no
Guarantee , but please first read & look how it must be done ,
good luck / gefattern
( to short you need a small piece of copper wire or similar )
Originally posted by iamsushantsharma View PostBrilliant!!!!!!
I was able to get the device connected. It appears in USB burning tool after shorting two pins.
But
I get error at 2%.
> I have tried clicking start and connecting later
>Unticking erase bootloader
These dont work. Please advise.
if you get a direct Error message , it is most a wrong Rom , what did the Error
Message say , did you use the right USB Cable / Flashcable , i am not a AML
Flasher , so i not really can help , dont give up , greetings / gefattern
There are currently 1855 users online. 1 members and 1854 guests.
