Huawei Mediaq M310
    Originally posted by reefmonger View Post
    I used xbmc xaf 12.1 2013050347b0a23c60 to make it run smooth. I will check when I get near my device.
    Oh dear, ive bricked it. Im stuck on a bootloop after rooting it.I cant find any Roms or Windows drivers for it. Ive never seen a device so poorly supported.
      This is where I found it.
      http://goo.im/devs/kemonine/xbmc
        Well, thank God after 2 days of trying ive managed to unbrick it. Buried away on the Chinese Huawei site, there is a firmware update which i downloaded. I then extracted the "dload" file from the zip file and placed it on my sd card and started the box and it installed! The firmware is in Chinese but you can change the language in the settings. Interestingly, the stock launcher has changed and it seems smoother. This firmware was dated the 25th of Oct so it must be a recent update.Im not sure how region specific it ,ill have to have a look in depth.
          Re: Huawei Mediaq M310
          Nice work Batfink. I believe this product has only been released in China. Your right there is no information anywhere. I've called Huawei in Canada and USA and they tell me its not released yet. I'm watching a movie on xbmc right now and its smooth as silk.
          Sent from my SGH-I747M using Tapatalk 2
            Ahhh I see, well the firmware I have is all in Chinese with no option to change to English there's all sorts of Customised Chinese stuff , no Google Play either. I guess they'll release the English firmware at somepoint.
            Sent from my Faea HY509S using Tapatalk
              I noticed while watching a 1080 movie last nite the hw symbol in the top right corner. Does this mean its hardware decoding?
                In MX Player? Yes it does .
                Sent from my Faea F2S using Tapatalk
                  Just like Batfink32 I am having all kinds of problems running xbmc on this box. reefmonger, do you use external player with xbmc?
                  I can't figure out how to screen mirror. Maybe that feature is only supported on huawei products.
                    yes I am using mx player with xbmc 12.1 xaf special build
                      I can find out how to screen mirror either.
                      Apparently the Hisilikon Soc doesn't have libstagefright support therefore XBMC isnt compatible with it. You will have to use an external player. Also notice the CPU is clocked at a Max of 1.2 MHz, although the Hisilikon has a frequency of 1.5. I think its clocked at a lower frequency because the box gets quite hot.
                        what version of mx player are you using with? I can't get it(version Pro 1.7.19) to work with youtube videos though other add-ons seem to work just fine. Every time a youtube video is clicked I get "can't play the video" error message.
                          That makes sense.
                          Screen mirroring was one of the reasons I got this box, so it's a little bit disappointing not to be able to do that. Hopefully they would release an firmware update based on android 4.2 or higher which includes miracast support
                            YouTube in XBMC? It doesnt work on XBMC XAF as there are script errors in that version. You'll need to use the Youtube app.
                              yes, in XBMC. I found a fix online, sort of. You have to go into youtube add-on settings and change "Max video quality" to ask(default is 720p), downside of this is it asks you to select resolution every time a video is played. I still do get script error on some videos.
                                I wont be able to see what version untill Friday
