And of course TWRP or CWM?
Any Android TV 8 or Android TV 9 (ATV) ROM for Allwinner H6 soc available? TWRP or CWM recovery?
twrp for tanix tx6
TWRP_TX6.zip - copy it to a USB flash drive (required because stock recovery does not see the SD card) - reboot into stock recovery - select Apply update from External - select TWRP_TX6.zip there and load into TWRP.
https://mega.nz/#!HMVRGQhS!gtyhlYael...WpzhYkUsx88qwM
Originally posted by mike808 View PostIs there a way I can install youtube vanced on the TX6 box? It's rooted, and the instructions say to flash the installer files using twrp. Any alternative method to install youtube vanced? This version of TWRP won't let me flash the installer files.
First thing I do is uninstall the YouTube app that comes in the ROM, then install both Vanced and MicroG, then in app settings of Vanced you select Opening Links and choose to open "All Links" so if another app tries to send you to a YouTube link redirect then Vanced will be the app that opens the YouTube video.
Originally posted by RiCkLaR_atvX View Post
The standard Vanced for non-root devices works great, you just need to also install the add-on apk "Vanced MicroG" to be able to sign-in to your Google Account and get all your channel subscriptions and watchlists.
Hi There, i have been trying to recover a Tanix TX6 all weekend and would like to try the twrp method. Back up a working Tanix TX6 then restore the image to the blank box, if this is even possible.
I have found some very useful videos on youtube using twrp buit I can't even get that on the good box. I have downloaded your zip file but when I boot into recovery I dont get select update from USB, only sd or adb. Can you please tell me what im doing wrong .
many thanks in advance
i tried to make backup with the 4pda TWRP from jjonas and got some error message: could not find partition for path \system
Look also here my other posting here: https://forum.freaktab.com/forum/tv-...010#post790010
Originally posted by budo View PostI am looking for a rom generic Tanix TX 6 with Allwinner H6
or search FreakTab for LibreELEC which Balbes50 has made for the Allwinner H6 and the default dtb is for TX6 devices, no need to change anything, just load img with etcher to a sdcard and insert into device and have the best LibreELEC image available or you can get nightly images straight from LibreELEC which don't have all the updates that Balbes installs.
Originally posted by PedroHque122 View PostHi, guays. I need the firmware of the TX6 2GB RAM/16 ROM. Can be Android 9 or Android 7. I want only have a backup becouse maebe problem . Sorry my english. I am from Brazil.
https://mega.nz/file/ZnRzXKIY#P84Jby...oG62Z8Te3IAFHE
https://mega.nz/file/x3JSgKBL#tcePYr...HY_f6PCd2vI36o
https://mega.z /YqZk2SZL#oCzgTe...C1j6eefPJqVVaY
There are currently 2305 users online. 2 members and 2303 guests.
