Originally posted by Adware View Post
how to pass safety net using props module? what is the option?
That should work.
Also change Magisk package name in it's settings and also activate Hide Magisk.
Also delete the su binary file in /system/xbin
using Termux from GooglePlay I type su and agree to give root access and then type props and I got the necessary commands threre
Originally posted by Rani2add View Post
After rooting with Magisk . I installed MagiskHide Props Config module.
Just did it on my AM6 and it's working.
Post screenshots of your props screen if you still have trouble.
Hi, I did everything in this lesson. But there is no result. There is no Ugoos AM6 in the Terminal Emulator itself or in Termux. I have the commodity version 0.3.9.
http://kalenderfamily.de/?file=start...-android-9-pie
mo123 Then you just restart the device.
After rebooting, the ugoos went into bootloop
The lesson says they need to be restarted one by one, otherwise probably because of this he enters the bootlop.
But how to do it, restart them, one by one?
Select all the different entries to emulate of the device, just say no to restart for each one, when you changed all 6 or 7 entries then you can restart for the last one.Last edited by Hubo; 02 January 2021, 12:48.
mo123
When restarting one by one, up to 9 options there are no problems, but when restarting 10 options ro.product.model Ugoos enters Bootlop. What is the solution to this problem?
I reinstall twice and both times the bootlop appears when restarting 10 options. How to solve the problem with 10 ro.product.model option?
There are currently 1942 users online. 0 members and 1942 guests.
