PicUntu-4.5-nand-BasicGUI installer - One file, few click install.
    Team, Close on the heals of release of 4.4.3, we are happy to present PicUntu 4.5-nand-BasicGUI, A complete Linux distribution all images (yes kernel, system, boot et all) AND the installer. The zipped file and a few clicks, will be all it takes, to get your own PicUntu.
    Link to the file is here
    --- > PicUntu 4.5-nand-BasicGUI
    PicUntu 4.5 Basic Installer kit
    aims to make the installation, configuration and operations easy and convenient for end user to be able to use it, without worrying about the technology behind it. Click image for larger version
Name:	Screenshot - 100813 - 16:29:50.jpg
ID:	438649 All this packed in less than 247 MB !! - that's PicUntu 4.5-NAND-BasicGUI-kit
    What does it do?
    One click (actually 4 ) install of PicUntu on Android stick. Click image for larger version
Name:	Screenshot - 100813 - 16:22:43.jpg
    Who is it for?
    • Home use, multimedia users - even with 720p video files, the average load on CPU does not go beyond 30-35%.
    • Small servers, linux desktops, linux webservers (http://picuntu.g8.net is a web-server running on PicUntu 2.2 since Feb 2013)
    • In addition to the home users for the multi-media PicUntu-4.5 is the first business device that works out-of-the box for business users as well.
    • It is snappy, fast and robust.
    What device is it for ?
    Currently, this is optimized for MK802IV, but will work for many other 3188 devices (though I have yet to test them). Will be releasing kernels for other devices soon.
    *** EDIT Oct 12th *** Important for MK802IV 16gb owners.
    I found out that the Mk802IV 16 gb model used to fail every-time I was trying to flash it. This was observed by other folks too. Thanks to the awesome work by Milkboy, we now have a fix for it.
    Very peculiarly the 16GB model fails to flash, if you are using the Rockchip 1.20 bootloader version, you have to use Rockchip 1.24 bootloader version.
    You can find the Rockchip 1.24 bootloader here.
    So, after you unzip the PicUntu 4.5 Nand zip file, make sure, you replace the included Rockchip bootloader 1.20 with the 1.24 version, and then flash.
    *** Edit End ***
    What does it have?
    • It has PicUntu 4.5 - kernels, boot, system file, with basic GUI.
    • It is based on Ubuntu 13.04, with xfce4.
    • I have added support for more than 200+ drivers, it should be a breeze to connect peripherals to this. If not, let me know with a pointer to source and I will try to get the driver compiled.
    • File system support - nfs, ntfs, cramfs, cifsutils, smb... - several remote controls, external usb ethernet, external usb wifi, vpn, pptp, vtun, Serial port - FTD, usb serial, UART, GPS-Garmin, sound card, touch screen... and many more (more than 200.)
    • Built in RDP application - run it like a powerful and hybrid thin client - to run and access Windows/Linux/Other OS.
    • Lot of tweaking has been done on the system level to make it responsive and blazing fast - Give it a spin, you would see the difference yourself.
    • Sound/Video work off the first boot.
    • Wlan0 should be pre-loaded, just click on the wicd-network to configure for your network.
    *** WARNING ***
    • This package deletes all data from the your device. Your ANDROID will be gone !!
    • MOST manufacturers will void their warranty, if you flash un-authorized ROMs
    • I have heard of people bricking their device permanently, though I have yet to witness this.
    • So please be careful, you would be responsible for your own loss - or loads of fun.
    *** WARNING ****
    How do I install this?
    1. Use Windows machine, Download picuntu-4.5-nand-complete.zip. Unzip at any location.
    2. Click on rk_flash_1.37--> RKAndroidtool.exe
    3. At this time you need to get the device in bootloader mode. Use a pin to press the button on the device (this is explained on the forums) or run reboot bootloader in android.
    4. On your windows PC, when the application is launched, you should see at the bottom - "Device Found for Flashing"
    5. ** If you get that message go ahead, if not go back to step 5 and 6 till you get the message "Device Found for Flashing" ***
    6. Make sure that the following options are CHECKED
      1. binloader
      2. parameter
      3. kernel
      4. boot
      5. system
    7. Basically the following have to be UNCECKED (NOT SELECTED)
      1. misc
      2. recovery
      3. backup
      4. (I don't yet know how to configure the flashtool, once I do, step 7 can be eliminated - if some kind soul can share with me - I will be obliged)
    8. First Erase NAND
    9. Select Flash ROM
    The device should now boot into a fresh new PicUntu. * IMPORTANT NOTE * - The first boot
    • The first time, it boots, it will take a while to come up... lot of work goes on , filesystem is resized, wifi module is modprobed. and other minor optimization. It might even appear to have stalled, wait for it to come back. It will come back.
    • If it does not boot into the GUI the first time - after having waited for about 3-5 minutes.
    • Reboot the device. This time it should be faster.
    • The login user is "picuntu" the password is "12qwaszx" (please change this password asap)
    What does not work (yet)
    - Hardware video acceleration
    - Bluetooth.
    - My Lenovo Touchscreen :-(
    Some key people who deserve credit for this work
    - mmm123 (for sharing his learning)
    - leolas (always eager to help)
    - linuxium (for the nand configuration file, partition schema, rkwifi.ko insertion.. and many more things...
    - Galland - (for his nice work on framebuffers, video and basically everything hardware)
    - Omegamoon and Astralix have been instrumental in getting the PicUntu going on the 3188 devices. Including the latest 3.0.72+ sources, which is available for use on his github.
    - I used Finless ROMs parameter files and his postings to learn about the basics of boot.img
    - I used rk3xxmodtools to zip/unzip create boot image files... (have a shell script file now) - Borrowed from several users on the forums - the small tips of things they have solved various issues - from time, to sound, to many other...
    - Andrew Kirby, Perry Kivolowitz have been extra-ordinarily generous with their support by sponsoring development devices. Many devices were received.
    - Several people have contributed for documenting
    - many more who I may have missed above, but their work deserves accolades.
    Source + .Config
    The source used is from the original Linux3188 source code released - this is where it is
    https://github.com/aloksinha2001/Linux3188
    All kernels, I create have
    /proc/config.gz enabled, just use any of the devices to use the same for your own kernels.
    EDIT: This one does NOT have the /proc/gz - My bad, I have updated the config file on the github, you can get the same here. The next updated version will carry this.
    Linux users
    Can you use Linux to flash this into your stick. You can theoritically flash the images - boot, kernel, system at the respective places using Linux desktop. There are also some very awesome tools created by linuxerwang, galland that help you flash the files. However, for large file transfers, there is always a scope of errors to creep in. And hence, more often than not it fails. Perry was working on this, and he put in some checks at each write and read - but, I am not sure, if the final files have been working (specially for large files - system.img decompresses to 1.2Gb)
    What happens, if I want my android back
    Worry not, you can always switch back to andrioid, by flashing back the stock rom or the various - very nice android custom roms available across various forums. Ofcourse, you would have to let go of PicUntu. 7z I have never been a fan of the LZMA format, even though I knew they give a higher compression settings... Tar/gz was working great for me. BUT... seeing others use this format, I wondered if it would give enough reasons for the shift. And sure enough, it shaved off about 25% of the file size in compression. (another learning from the forums). WinRAR will be a good option to uncompress this.
    What's Next
    • Other devices to be supported - I am keen on R42, TronSmart T428, MK908, RADXA..
    • Release a 'full' gui version, with complete processing world - gimp, libreoffice, media players, editors etc. Even now, you can manually do this by add the specific applications.
    • Release a 'server' version to run headless. You can pretty much install any server even today (available from Ubuntu 13.04) repos. We will make it pre-loaded and pre-configured.
    • More drivers.
    • But most importantly, we would continue to make it more and more simple for the end user.
    Alok
    Last edited by aloksinha2001; 14 October 2013, 02:37. Reason: Update for Mk8082IV 16GB model
    oh my God!
    Finally, a smart, very low consumption, fully usable and simply to install cheap pc desktop.
    Thank you everyone.
    The world is changing and I think that the attention at the energy consumption is really important.
    P.S. Can i hope on a version for mk808?
      I have tried your image on my device MK812A (CPU RK3188 + WiFi MTK5931).
      It does not show any activity on screen.
      My device uses LCDC0 as TV output in Android.
      Perhaps your image is compiled for LCDC1 as TV output ?
      If so, can you please recompile your image for LCDC0 as TV output ?
        Is it only LCD0 that is required ?
        Alok
          Kernel.config / proc / config.gz file not found
          Hi all great thanks for the great job .
          Terminal command: dmesg shows the kernel is configured to LCDC0.
          Push erase flash first then push write.
          I have another question.
          I have a rtl8188 wifi does not work
          Kernel config / proc / config.gz file not found.
          It may be somewhere else have any suggestions welcome.
            Thanks for such a wonderful gift
            Originally posted by aloksinha2001 View Post
            Team,
            PicUntu 4.5 Basic Installer kit aims to make the installation, configuration and operations easy and convenient for end user to be able to use it, without worrying about the technology behind it.
            [ATTACH=CONFIG]3466[/ATTACH]
            What does it do?
            [ATTACH=CONFIG]3468[/ATTACH]
            Who is it for?
            What does it have?
            *** WARNING ***
            *** WARNING ****
              1. binloader
              2. parameter
              3. kernel
              4. boot
              5. system
              1. misc
              2. recovery
              3. backup
            8. First Erase NAND
            9. Select Flash ROM
            - Bluetooth.
            - linuxium (for the nand configuration file, partition schema, rkwifi.ko insertion.. and many more things...)
            Source + .Config
            Linux users
            7z
            What's Next
            • More drivers.
            Thanks for this goodee....
            By bluetooth not working you mean internal bluetooth....., right....?
            We still can use usb bluetooth dongles ... right....? Please clarify...
              Yes.
              Yes.
              Alok
                1. rtl8188 will not work by default, as the default wifi module is conifgured to be as AP6210. You can try to insert the android driver - found in /lib/modules/
                But I have found it the 8188eu to work nicely with native compile.
                2. My bad - the kernel has missed the /proc/config support (Damn!) . I will have to update the posted kernels again... will do... in the meanwhile, Please let me know which config file you want to try on and I will send you the same.
                Alok
                  Alok
                  Hi, Alok. I also want the config file. They only differ on HDMI, right? I don't care about HDMI, so can you please share with me any of them?
                  Thanks!
                    Thanks!
                    Updated the config file on the github.
                    Alok
                      Thanks! Look forward to the new 3.0.72+ kernel.
                        Sorry, I'm a noob, so don't know.
                        I did erase NAND first, then flash ROM, but still no activity on screen.
                          So, and where is the download link???
                            re download link
                            link is in top post
                            ((Close on the heals of release of 4.4.3, we are happy to present
                            PicUntu 4.5-nand-BasicGUI,))
                            (http://www.g8.net/download/4.5/picun...sicgui-nand.7z)
                            i installed on t428 but is asking for password can some one post user password
                            thanks in advance
                              Originally posted by main3dtv View Post
                              link is in top post
                              thanks in advance
                              As always, password is "12qwaszx".
