PicUntu-4.5-nand-BasicGUI installer - One file, few click install.
    Can someone please tell me what do I need to do change the resolution?my monitor cant support this high resolution .... (My monitor just displays:Not optimum resolution please change the resolution to 1680x1050 )and than it starts flashing like crazy
    Thanks in advance!
      Thanks in advance!
      kernel 720p flash
        ь
        Originally posted by vmkogeretla View Post
        Ура!!! У вас установлен Xubuntu 13.04!!!
        Не подскажешь, как адаптировать это под MK908 ?
          Originally posted by dmit9 View Post
          MK908 ?
          Sent to the PM.
            Re: PicUntu-4.5-nand-BasicGUI installer - One file, few click install.
            How to get LibreOffice in this?
            edit: ignore it. After removing ppa added by me got it installed.
            Sent from my XT901 using Tapatalk
              add kernels: http://yadi.sk/d/R9By8N49C3kLE/
              It's not for Picuntu. It's just for my image, which must still be installed after the firmware.
                How to backup the device
                All,
                Is there an easy way to make a backup of the device once I've customised it? e.g. using the flashtool?
                Basically, my device is hooked up to a tv and it is regularly powered off, and recently it completely corrupted the picuntu installation, so I've had to reinstall. Before I spend a day or two updating my configs, autoboot to openbox, load chromium, install extensions, configure default pages etc... I wanted to find a way to make a backup I can then use to rebuild the device - via flashtool? - if it ever corrupts again.
                Any suggestions would be a appreciated....
                Cheers
                  Originally posted by Martyzz1 View Post
                  All,
                  Cheers
                  http://www.freaktab.com/showthread.php?5867-A-GUI-tool-for-flashing-rk3066-rk3188-kernel-image-under-Linux
                  (backup partition, flash partition)
                  or
                  Rootfs copy to another folder, exclude
                  (/dev/*,/proc/*,/sys/*,/tmp/*,/run/*,/mnt/*,/media/*,/lost+found)
                  Midnight Commander (sudo apt-get install mc), sudo mc
                    or
                    The flashtool link. I presume I need to run this on another linux device? (I've been using windows so far) I'd use my mac, but there doesn't seem to be any tools for it out there)
                      and virtualbox
                        *** WARNING ***
                        This package deletes all data from the your device. Your ANDROID will be gone !!
                        MOST manufacturers will void their warranty, if you flash un-authorized ROMs
                        I have heard of people bricking their device permanently, though I have yet to witness this.
                        So please be careful, you would be responsible for your own loss - or loads of fun.
                        *** WARNING ****
                        Try http://yadi.sk/d/R9By8N49C3kLE/
                        Based on ubuntu core
                        And so:
                        1. Insertion
                        2. Boot (first time for a long time because the expanding section) should occur automatically reboot.
                        3. Boot the second time and enter: User: root Pass: root
                        4.
                        Code:
                        /Install.sh
                        (kachatsya Do not be, everything is downloaded.)
                        5. Answer the questions:
                        a) The user password
                        b) Keyboard
                        c) Setting Encoding
                        6. We are waiting for the installation
                        7.
                        Code:
                        reboot
                        Hurrah! Have you installed Xubuntu 13.04!!!
                        И так:
                        1. Прошиваем
                        2. Грузимся (Первый раз долго потому как расширяется раздел), должна произойти автоматическая перезагрузка.
                        3. Второй раз загружаемся и входим: User:root Pass:root
                        4.
                        Code:
                        /Install.sh
                        (Ничего качаться не будет, все уже скачено.)
                        5. Отвечаем на вопросы:
                        а) Пароль пользователя
                        б) Раскладка клавиатуры
                        в) Настройка кодировки
                        6. Ждем окончания установки
                        7.
                        Code:
                        reboot
                        Thanks you very much but could not install.when I give input usr and pass as root ,and /install.sh ,it's installing something but in the middle it reboots and I had to repeat same process.will it work on mk802iv ?and another thing is that I really need adobe flash player work on it .still now no success
                          http://yadi.sk/d/dWRSwlQwCCouX - adobeflash-chromium-arm-vmk.tar.gz
                            Originally posted by Onion View Post
                            Hey guys, I got Picuntu to work on my Dell monitor, but can't see the edges of the screen, i.e. if I maximize any window, I can't manipulate the 3 controls (Minimize, Maximize and Exit), because the edges are out of view. It says it's in the 1080p mode. When I do fbset -s, it shows 1920 1080 60:
                            Code:
                            sudo fbset -s
                            picuntu@g8picuntu:~$ sudo fbset -s
                            [sudo] password for picuntu:
                            mode "1920x1080-60"
                            # D: 148.500 MHz, H: 67.500 kHz, V: 60.000 Hz
                            geometry 1920 1080 1920 1080 16
                            timings 6734 148 88 36 4 44 5
                            nonstd 4
                            rgba 5/11,6/5,5/0,0/0
                            endmode
                            But I don't even see this setting in fb.modes (I had to format some comments because it went over 24K characters):
                            Code:
                            # Mach64 Programmer's Guide, Appendix C
                            # (C) 1998 ATI Technologies Inc.
                            # Kop: this are very generic modes and not only for ATI cards.
                            # 640x480, 60 Hz, Non-Interlaced (25.175 MHz dotclock)
                            # Polarity negative negative
                            mode "640x480-60"
                            # D: 25.175 MHz, H: 31.469 kHz, V: 59.94 Hz
                            geometry 640 480 640 480 8
                            timings 39722 48 16 33 10 96 2
                            endmode
                            # 640x480, 72 Hz, Non-Interlaced (31.20 MHz dotclock)
                            mode "640x480-72"
                            # D: 31.20 MHz, H: 37.500 kHz, V: 72.12 Hz
                            timings 32052 128 24 28 9 40 3
                            endmode
                            # 640x480, 75 Hz, Non-Interlaced (31.50 MHz dotclock)
                            mode "640x480-75"
                            # D: 31.50 MHz, H: 37.500 kHz, V: 75.00 Hz
                            timings 31747 120 16 16 1 64 3
                            endmode
                            # 640x480, 90 Hz, Non-Interlaced (39.91 MHz dotclock)
                            mode "640x480-90"
                            # D: 39.91 MHz, H: 47.969 kHz, V: 90.00 Hz
                            timings 25057 120 32 14 25 40 14
                            endmode
                            # 640x480, 100 Hz, Non-Interlaced (44.90 MHz dotclock)
                            mode "640x480-100"
                            # D: 44.90 MHz, H: 52.948 kHz, V: 99.71 Hz
                            timings 22272 48 32 17 22 128 12
                            endmode
                            # 768x576, 75 Hz, Non-Interlaced (49.188 MHz dotclock)
                            # This is a mode often used, because fbtv suggests this, since
                            # this is the mode for "normal" TVs.
                            mode "768x576-75"
                            # D: 49.188 MHz, H: 46.580 kHz, V: 75.008 Hz
                            geometry 768 576 768 576 32
                            timings 20330 128 32 32 8 128 5
                            endmode
                            # 800x600, 48 Hz, Interlaced (36.00 MHz dotclock)
                            mode "800x600-48-lace"
                            # D: 36.00 MHz, H: 33.835 kHz, V: 96.39 Hz
                            geometry 800 600 800 600 8
                            timings 27778 56 80 79 11 128 12
                            laced true
                            hsync high
                            vsync high
                            endmode
                            # 800x600, 56 Hz, Non-Interlaced (36.00 MHz dotclock)
                            mode "800x600-56"
                            # D: 36.00 MHz, H: 35.156 kHz, V: 56.25 Hz
                            timings 27778 128 24 22 1 72 2
                            hsync high
                            vsync high
                            endmode
                            # 800x600, 60 Hz, Non-Interlaced (40.00 MHz dotclock)
                            mode "800x600-60"
                            # D: 40.00 MHz, H: 37.879 kHz, V: 60.32 Hz
                            timings 25000 88 40 23 1 128 4
                            hsync high
                            vsync high
                            endmode
                            # 800x600, 70 Hz, Non-Interlaced (44.90 MHz dotclock)
                            mode "800x600-70"
                            # D: 44.90 MHz, H: 44.544 kHz, V: 70.04 Hz
                            timings 22272 40 24 15 9 144 12
                            hsync high
                            endmode
                            # 800x600, 72 Hz, Non-Interlaced (50.00 MHz dotclock)
                            mode "800x600-72"
                            # D: 50.00 MHz, H: 48.090 kHz, V: 72.19 Hz
                            timings 20000 64 56 23 37 120 6
                            hsync high
                            vsync high
                            endmode
                            # 800x600, 75 Hz, Non-Interlaced (49.50 MHz dotclock)
                            mode "800x600-75"
                            # D: 49.50 MHz, H: 46.875 kHz, V: 75.00 Hz
                            timings 20203 160 16 21 1 80 3
                            hsync high
                            vsync high
                            endmode
                            # 800x600, 90 Hz, Non-Interlaced (56.64 MHz dotclock)
                            mode "800x600-90"
                            # D: 56.64 MHz, H: 57.097 kHz, V: 89.92 Hz
                            timings 17656 120 8 16 8 64 11
                            hsync high
                            vsync high
                            endmode
                            # 800x600, 100 Hz, Non-Interlaced (67.50 MHz dotclock)
                            mode "800x600-100"
                            # D: 67.50 MHz, H: 62.500 kHz, V: 100.00 Hz
                            timings 14815 216 0 14 7 64 4
                            hsync high
                            vsync high
                            endmode
                            # 1024x768, 43 Hz, Interlaced (44.90 MHz dotclock)
                            # Horizontal Vertical
                            # Resolution 1024 768
                            # Scan Frequency 35.522 kHz 86.96 Hz
                            # Sync Width 3.920 us 0.113 ms
                            # 22 chars 8 lines
                            # Front Porch 0.178 us 0.014 ms
                            # 1 chars 1 lines
                            # Back Porch 1.247 us 0.563 ms
                            # 7 chars 40 lines
                            # Active Time 22.806 us 10.810 ms
                            # 128 chars 768 lines
                            # Blank Time 5.345 us 0.690 ms
                            # 30 chars 49 lines
                            # Polarity positive positive
                            mode "1024x768-43-lace"
                            # D: 44.90 MHz, H: 35.522 kHz, V: 86.96 Hz
                            geometry 1024 768 1024 768 8
                            timings 22272 56 8 40 1 176 8
                            laced true
                            hsync high
                            vsync high
                            endmode
                            # 1024x768, 60 Hz, Non-Interlaced (65.00 MHz dotclock)
                            # Scan Frequency 48.363 kHz 60.00 Hz
                            # Sync Width 2.092 us 0.124 ms
                            # 17 chars 6 lines
                            # Front Porch 0.369 us 0.062 ms
                            # 3 chars 3 lines
                            # Back Porch 2.462 us 0.601 ms
                            # 20 chars 29 lines
                            # Active Time 15.754 us 15.880 ms
                            # Blank Time 4.923 us 0.786 ms
                            # 40 chars 38 lines
                            mode "1024x768-60"
                            # D: 65.00 MHz, H: 48.363 kHz, V: 60.00 Hz
                            timings 15385 160 24 29 3 136 6
                            endmode
                            # 1024x768, 70 Hz, Non-Interlaced (75.00 MHz dotclock)
                            # Scan Frequency 56.476 kHz 70.07 Hz
                            # Sync Width 1.813 us 0.106 ms
                            # 17 chars 6 lines
                            # Front Porch 0.320 us 0.053 ms
                            # 3 chars 3 lines
                            # Back Porch 1.921 us 0.514 ms
                            # 18 chars 29 lines
                            # Active Time 13.653 us 13.599 ms
                            # Blank Time 4.053 us 0.673 ms
                            # 38 chars 38 lines
                            mode "1024x768-70"
                            # D: 75.00 MHz, H: 56.476 kHz, V: 70.07 Hz
                            timings 13334 144 24 29 3 136 6
                            endmode
                            # 1024x768, 72 Hz, Non-Interlaced (75.00 MHz dotclock)
                            # Scan Frequency 58.230 kHz 72.245 Hz
                            # Sync Width 1.813 us 0.103 ms
                            # 17 chars 6 lines
                            # Front Porch 0.320 us 0.052 ms
                            # 3 chars 3 lines
                            # Back Porch 1.387 us 0.498 ms
                            # 13 chars 29 lines
                            # Active Time 13.653 us 13.189 ms
                            # Blank Time 3.520 us 0.653 ms
                            # 33 chars 38 lines
                            mode "1024x768-72"
                            # D: 75.00 MHz, H: 58.230 kHz, V: 72.245 Hz
                            timings 13334 104 24 29 3 136 6
                            endmode
                            # 1024x768, 75 Hz, Non-Interlaced (78.75 MHz dotclock)
                            # Scan Frequency 60.023 kHz 75.03 Hz
                            # Sync Width 1.219 us 0.050 ms
                            # 12 chars 3 lines
                            # Front Porch 0.203 us 0.017 ms
                            # 2 chars 1 lines
                            # Back Porch 2.235 us 0.466 ms
                            # 22 chars 28 lines
                            # Active Time 13.003 us 12.795 ms
                            # Blank Time 3.657 us 0.533 ms
                            # 36 chars 32 lines
                            mode "1024x768-75"
                            # D: 78.75 MHz, H: 60.023 kHz, V: 75.03 Hz
                            timings 12699 176 16 28 1 96 3
                            hsync high
                            vsync high
                            endmode
                            # 1024x768, 90 Hz, Non-Interlaced (100.0 MHz dotclock)
                            # Scan Frequency 76.220 kHz 90.20 Hz
                            # Sync Width 0.960 us 0.197 ms
                            # 12 chars 15 lines
                            # Front Porch 0.000 us 0.276 ms
                            # 0 chars 21 lines
                            # Back Porch 1.920 us 0.537 ms
                            # 24 chars 41 lines
                            # Active Time 10.240 us 10.076 ms
                            # Blank Time 2.880 us 1.010 ms
                            # 36 chars 77 lines
                            mode "1024x768-90"
                            # D: 100.0 MHz, H: 76.220 kHz, V: 90.20 Hz
                            timings 10000 192 0 41 21 96 15
                            endmode
                            # 1024x768, 100 Hz, Non-Interlaced (110.0 MHz dotclock)
                            # Scan Frequency 79.023 kHz 99.78 Hz
                            # Sync Width 0.800 us 0.101 ms
                            # 11 chars 8 lines
                            # Front Porch 0.000 us 0.000 ms
                            # 0 chars 0 lines
                            # Back Porch 2.545 us 0.202 ms
                            # 35 chars 16 lines
                            # Active Time 9.309 us 9.719 ms
                            # Blank Time 3.345 us 0.304 ms
                            # 46 chars 24 lines
                            mode "1024x768-100"
                            # D: 110.0 MHz, H: 79.023 kHz, V: 99.78 Hz
                            timings 9091 280 0 16 0 88 8
                            endmode
                            # 1152x864, 43 Hz, Interlaced (65.0 MHz dotclock)
                            # Resolution 1152 864
                            # Scan Frequency 45.904 kHz 87.02 Hz
                            # Sync Width 1.969 us 0.098 ms
                            # 16 chars 9 lines
                            # Front Porch 1.062 us 0.850 ms
                            # 9 chars 78 lines
                            # Back Porch 1.031 us 1.133 ms
                            # 8 chars 104 lines
                            # Active Time 17.723 us 9.411 ms
                            # 144 chars 864 lines
                            # Blank Time 4.062 us 2.080 ms
                            # 33 chars 191 lines
                            mode "1152x864-43-lace"
                            # D: 65.0 MHz, H: 45.904 kHz, V: 87.02 Hz
                            geometry 1152 864 1152 864 8
                            timings 15385 64 72 104 78 128 9
                            laced true
                            hsync high
                            vsync high
                            endmode
                            # 1152x864, 47 Hz, Interlaced (65.0 MHz dotclock)
                            # Scan Frequency 44.890 kHz 94.80 Hz
                            # Sync Width 1.969 us 0.100 ms
                            # 16 chars 9 lines
                            # Front Porch 1.415 us 0.334 ms
                            # 11 chars 30 lines
                            # Back Porch 1.170 us 0.490 ms
                            # 10 chars 44 lines
                            # Active Time 17.723 us 9.624 ms
                            # Blank Time 4.554 us 0.924 ms
                            # 37 chars 83 lines
                            mode "1152x864-47-lace"
                            # D: 65.0 MHz, H: 44.890 kHz, V: 94.80 Hz
                            timings 15385 80 88 44 30 128 9
                            laced true
                            hsync high
                            vsync high
                            endmode
                            # 1152x864, 60 Hz, Non-Interlaced (80.0 MHz dotclock)
                            # Scan Frequency 54.945 kHz 59.98 Hz
                            # Sync Width 1.400 us 0.091 ms
                            # 14 chars 5 lines
                            # Front Porch 0.800 us 0.109 ms
                            # 8 chars 6 lines
                            # Back Porch 1.600 us 0.746 ms
                            # 16 chars 41 lines
                            # Active Time 14.400 us 15.725 ms
                            # Blank Time 3.800 us 0.946 ms
                            # 38 chars 52 lines
                            mode "1152x864-60"
                            # D: 80.0 MHz, H: 54.945 kHz, V: 59.98 Hz
                            timings 12500 128 64 41 6 112 5
                            hsync high
                            vsync high
                            endmode
                            # 1152x864, 70 Hz, Non-Interlaced (100.0 MHz dotclock)
                            # Scan Frequency 66.138 kHz 69.99 Hz
                            # Sync Width 1.520 us 0.166 ms
                            # 19 chars 11 lines
                            # Front Porch 0.390 us 0.197 ms
                            # 5 chars 13 lines
                            # Back Porch 1.690 us 0.862 ms
                            # 21 chars 57 lines
                            # Active Time 11.520 us 13.064 ms
                            # Blank Time 3.600 us 1.225 ms
                            # 45 chars 81 lines
                            mode "1152x864-70"
                            # D: 100.0 MHz, H: 66.138 kHz, V: 69.99 Hz
                            timings 10000 168 40 57 13 152 11
                            hsync high
                            vsync high
                            endmode
                            # 1152x864, 75 Hz, Non-Interlaced (110.0 MHz dotclock)
                            # Scan Frequency 75.137 kHz 74.99 Hz
                            # Sync Width 1.309 us 0.106 ms
                            # 18 chars 8 lines
                            # Front Porch 0.245 us 0.599 ms
                            # 3 chars 45 lines
                            # Back Porch 1.282 us 1.132 ms
                            # 18 chars 85 lines
                            # Active Time 10.473 us 11.499 ms
                            # Blank Time 2.836 us 1.837 ms
                            # 39 chars 138 lines
                            mode "1152x864-75"
                            # D: 110.0 MHz, H: 75.137 kHz, V: 74.99 Hz
                            timings 9091 144 24 85 45 144 8
                            hsync high
                            vsync high
                            endmode
                            # 1152x864, 80 Hz, Non-Interlaced (110.0 MHz dotclock)
                            # Scan Frequency 76.389 kHz 79.74 Hz
                            # Sync Width 1.018 us 0.092 ms
                            # 14 chars 7 lines
                            # Front Porch 0.127 us 0.393 ms
                            # 2 chars 30 lines
                            # Back Porch 1.473 us 0.747 ms
                            # 20 chars 57 lines
                            # Active Time 10.473 us 11.311 ms
                            # Blank Time 2.618 us 1.231 ms
                            # 36 chars 94 lines
                            mode "1152x864-80"
                            # D: 110.0 MHz, H: 76.389 kHz, V: 79.74 Hz
                            timings 9091 160 16 57 30 112 7
                            hsync high
                            vsync high
                            endmode
                            # 1280x960, 75 Hz, Non-Interlaced (126.00 MHz dotclock)
                            # Resolution 1280 960
                            # Scan Frequency 74.788 kHz 74.788 Hz
                            # 14 chars 7 lines
                            # 2 chars 30 lines
                            # 20 chars 57 lines
                            # 36 chars 94 lines
                            mode "1280x960-75-8"
                            # D: 125.644 MHz, H: 74.788 kHz, V: 74.788 Hz
                            geometry 1280 960 1280 960 8
                            timings 7959 224 32 36 1 144 3
                            endmode
                            mode "1280x960-75"
                            geometry 1280 960 1280 960 16
                            endmode
                            mode "1280x960-75-32"
                            geometry 1280 960 1280 960 32
                            endmode
                            # 1280x1024, 43 Hz, Interlaced (80.00 MHz dotclock)
                            # Resolution 1024 1024
                            # Scan Frequency 50.000 kHz 87.03 Hz
                            # Sync Width 1.000 us 0.100 ms
                            # 10 chars 10 lines
                            # Front Porch 1.000 us 0.500 ms
                            # 10 chars 50 lines
                            # Back Porch 2.000 us 0.650 ms
                            # 20 chars 65 lines
                            # Active Time 16.000 us 10.240 ms
                            # 160 chars 1024 lines
                            # Blank Time 4.000 us 1.250 ms
                            # 40 chars 125 lines
                            mode "1280x1024-43-lace"
                            # D: 80.00 MHz, H: 50.000 kHz, V: 87.03 Hz
                            geometry 1024 1024 1024 1024 8
                            timings 12500 160 80 65 50 80 10
                            laced true
                            hsync high
                            vsync high
                            endmode
                            # 1280x1024, 47 Hz, Interlaced (80.00 MHz dotclock)
                            # Resolution 1280 1024
                            # Scan Frequency 50.000 kHz 94.97 Hz
                            # 10 chars 10 lines
                            # Front Porch 1.000 us 0.010 ms
                            # 10 chars 1 lines
                            # Back Porch 2.000 us 0.180 ms
                            # 20 chars 18 lines
                            # Blank Time 4.000 us 0.290 ms
                            # 40 chars 29 lines
                            mode "1280x1024-47-lace"
                            # D: 80.00 MHz, H: 50.000 kHz, V: 94.97 Hz
                            geometry 1280 1024 1280 1024 8
                            timings 12500 160 80 18 1 80 10
                            laced true
                            hsync high
                            vsync high
                            endmode
                            # 1280x1024, 60 Hz, Non-Interlaced (108.00 MHz dotclock)
                            # Scan Frequency 63.981 kHz 60.02 Hz
                            # Sync Width 1.037 us 0.047 ms
                            # 14 chars 3 lines
                            # Front Porch 0.444 us 0.015 ms
                            # 6 chars 1 lines
                            # Back Porch 2.297 us 0.594 ms
                            # 31 chars 38 lines
                            # Active Time 11.852 us 16.005 ms
                            # Blank Time 3.778 us 0.656 ms
                            # 51 chars 42 lines
                            mode "1280x1024-60"
                            # D: 108.00 MHz, H: 63.981 kHz, V: 60.02 Hz
                            timings 9260 248 48 38 1 112 3
                            hsync high
                            vsync high
                            endmode
                            # 1280x1024, 70 Hz, Non-Interlaced (126.00 MHz dotclock)
                            # Scan Frequency 74.645 kHz 70.02 Hz
                            # Sync Width 0.889 us 0.067 ms
                            # 14 chars 5 lines
                            # Front Porch 0.635 us 0.013 ms
                            # 10 chars 1 lines
                            # Back Porch 1.714 us 0.483 ms
                            # 27 chars 36 lines
                            # Active Time 10.159 us 13.718 ms
                            # Blank Time 3.238 us 0.563 ms
                            # 51 chars 42 lines
                            mode "1280x1024-70"
                            # D: 126.00 MHz, H: 74.645 kHz, V: 70.02 Hz
                            timings 7937 216 80 36 1 112 5
                            hsync high
                            vsync high
                            endmode
                            # 1280x1024, 74 Hz, Non-Interlaced (135.00 MHz dotclock)
                            # Scan Frequency 78.855 kHz 74.11 Hz
                            # Sync Width 1.067 us 0.380 ms
                            # 18 chars 30 lines
                            # Front Porch 0.237 us 0.000 ms
                            # 4 chars 0 lines
                            # Back Porch 1.896 us 0.127 ms
                            # 32 chars 10 lines
                            # Active Time 9.481 us 12.986 ms
                            # Blank Time 3.200 us 0.507 ms
                            # 54 chars 40 lines
                            mode "1280x1024-74"
                            # D: 135.00 MHz, H: 78.855 kHz, V: 74.11 Hz
                            timings 7408 256 32 10 0 144 30
                            hsync high
                            vsync high
                            endmode
                            # 1280x1024, 75 Hz, Non-Interlaced (135.00 MHz dotclock)
                            # Scan Frequency 79.976 kHz 75.02 Hz
                            # Sync Width 1.067 us 0.038 ms
                            # 18 chars 3 lines
                            # Front Porch 0.119 us 0.012 ms
                            # 2 chars 1 lines
                            # Back Porch 1.837 us 0.475 ms
                            # 31 chars 38 lines
                            # Active Time 9.481 us 12.804 ms
                            # Blank Time 3.022 us 0.525 ms
                            # 51 chars 42 lines
                            mode "1280x1024-75"
                            # D: 134.880 MHz, H: 79.905 kHz, V: 74.958 Hz
                            geometry 1280 1024 1280 3264 8
                            timings 7414 232 64 38 1 112 3
                            hsync high
                            vsync high
                            endmode
                            # 1600x1200, 60 Hz, Non-Interlaced (156.00 MHz dotclock)
                            # Resolution 1600 1200
                            # Scan Frequency 76.200 kHz 60.00 Hz
                            # Sync Width 1.026 us 0.105 ms
                            # 20 chars 8 lines
                            # Front Porch 0.205 us 0.131 ms
                            # 4 chars 10 lines
                            # Back Porch 1.636 us 0.682 ms
                            # 32 chars 52 lines
                            # Active Time 10.256 us 15.748 ms
                            # 200 chars 1200 lines
                            # Blank Time 2.872 us 0.866 ms
                            # 56 chars 66 lines
                            mode "1600x1200-60"
                            # D: 156.00 MHz, H: 76.200 kHz, V: 60.00 Hz
                            geometry 1600 1200 1600 1200 8
                            timings 6411 256 32 52 10 160 8
                            endmode
                            # 1600x1200, 66 Hz, Non-Interlaced (172.00 MHz dotclock)
                            # Scan Frequency 82.700 kHz 66.00 Hz
                            # Sync Width 0.791 us 0.036 ms
                            # 17 chars 3 lines
                            # Front Porch 0.233 us 0.036 ms
                            # 5 chars 3 lines
                            # Back Porch 1.767 us 0.567 ms
                            # 38 chars 47 lines
                            # Active Time 9.302 us 14.512 ms
                            # Blank Time 2.791 us 0.532 ms
                            # 60 chars 44 lines
                            mode "1600x1200-66"
                            # D: 172.00 MHz, H: 82.700 kHz, V: 66.00 Hz
                            timings 5814 304 40 47 3 136 3
                            endmode
                            # 1600x1200, 76 Hz, Non-Interlaced (198.00 MHz dotclock)
                            # Scan Frequency 95.200 kHz 76.00 Hz
                            # Sync Width 0.687 us 0.052 ms
                            # 17 chars 5 lines
                            # Front Porch 0.202 us 0.032 ms
                            # 5 chars 3 lines
                            # Back Porch 1.535 us 0.441 ms
                            # 38 chars 42 lines
                            # Active Time 8.081 us 12.606 ms
                            # Blank Time 2.424 us 0.525 ms
                            # 60 chars 50 lines
                            mode "1600x1200-76"
                            # D: 198.00 MHz, H: 95.200 kHz, V: 76.00 Hz
                            timings 5051 304 40 42 3 136 5
                            endmode
                            Openbox helps, because programs open by means of right-clicking the mouse, as opposed to edges (top left, top right, etc). Overall, it's doable, but if I could get to see the entire screen, that'd be great.
                            I had it connected to my TV and it was a TV setting cutting off the edges. Make sure its not your TV.
                              linux on mk908
                              Just follow the readme in https://doc-0o-40-docs.googleusercon...626&e=download
                              the original picuntu 4.5 does not work (because some hw/kernel differences) so you need to use above kit.
                              If not working, try using a kernel dedicated to mk908 v3.
                              Originally posted by ionutz View Post
                              how dit you do? i have a mk908 v3 and after flash my mk908 dont want to start.... congratulations to all people for this worksorry for bad english. i come from romania
                                work on mk908 but wifi dont
                                thanks for reply. now work but wifi dont want. i try with command line and not work
