I had the same issues as Sloepie.
If anyone has an easy way of getting Picuntu working on the MK908 pls share. Thanks
sudo fbset -s picuntu@g8picuntu:~$ sudo fbset -s [sudo] password for picuntu: mode "1920x1080-60" # D: 148.500 MHz, H: 67.500 kHz, V: 60.000 Hz geometry 1920 1080 1920 1080 16 timings 6734 148 88 36 4 44 5 nonstd 4 rgba 5/11,6/5,5/0,0/0 endmode picuntu@g8picuntu:~$
# # Mach64 Programmer's Guide, Appendix C # (C) 1998 ATI Technologies Inc. # # Kop: this are very generic modes and not only for ATI cards. # # # 640x480, 60 Hz, Non-Interlaced (25.175 MHz dotclock) # ... # Polarity negative negative # mode "640x480-60" # D: 25.175 MHz, H: 31.469 kHz, V: 59.94 Hz geometry 640 480 640 480 8 timings 39722 48 16 33 10 96 2 endmode # # 640x480, 72 Hz, Non-Interlaced (31.20 MHz dotclock) # ... # mode "640x480-72" # D: 31.20 MHz, H: 37.500 kHz, V: 72.12 Hz geometry 640 480 640 480 8 timings 32052 128 24 28 9 40 3 endmode # # 640x480, 75 Hz, Non-Interlaced (31.50 MHz dotclock) # ... # mode "640x480-75" # D: 31.50 MHz, H: 37.500 kHz, V: 75.00 Hz geometry 640 480 640 480 8 timings 31747 120 16 16 1 64 3 endmode # # 640x480, 90 Hz, Non-Interlaced (39.91 MHz dotclock) # ... # mode "640x480-90" # D: 39.91 MHz, H: 47.969 kHz, V: 90.00 Hz geometry 640 480 640 480 8 timings 25057 120 32 14 25 40 14 endmode # # 640x480, 100 Hz, Non-Interlaced (44.90 MHz dotclock) # ... # mode "640x480-100" # D: 44.90 MHz, H: 52.948 kHz, V: 99.71 Hz geometry 640 480 640 480 8 timings 22272 48 32 17 22 128 12 endmode # # 768x576, 75 Hz, Non-Interlaced (49.188 MHz dotclock) # ... # # This is a mode often used, because fbtv suggests this, since # this is the mode for "normal" TVs. # mode "768x576-75" # D: 49.188 MHz, H: 46.580 kHz, V: 75.008 Hz geometry 768 576 768 576 32 timings 20330 128 32 32 8 128 5 endmode # # 800x600, 48 Hz, Interlaced (36.00 MHz dotclock) # ... # mode "800x600-48-lace" # D: 36.00 MHz, H: 33.835 kHz, V: 96.39 Hz geometry 800 600 800 600 8 timings 27778 56 80 79 11 128 12 laced true hsync high vsync high endmode # # 800x600, 56 Hz, Non-Interlaced (36.00 MHz dotclock) # ... # mode "800x600-56" # D: 36.00 MHz, H: 35.156 kHz, V: 56.25 Hz geometry 800 600 800 600 8 timings 27778 128 24 22 1 72 2 hsync high vsync high endmode # # 800x600, 60 Hz, Non-Interlaced (40.00 MHz dotclock) # ... # mode "800x600-60" # D: 40.00 MHz, H: 37.879 kHz, V: 60.32 Hz geometry 800 600 800 600 8 timings 25000 88 40 23 1 128 4 hsync high vsync high endmode # # 800x600, 70 Hz, Non-Interlaced (44.90 MHz dotclock) # ... # mode "800x600-70" # D: 44.90 MHz, H: 44.544 kHz, V: 70.04 Hz geometry 800 600 800 600 8 timings 22272 40 24 15 9 144 12 hsync high endmode # # 800x600, 72 Hz, Non-Interlaced (50.00 MHz dotclock) # ... # mode "800x600-72" # D: 50.00 MHz, H: 48.090 kHz, V: 72.19 Hz geometry 800 600 800 600 8 timings 20000 64 56 23 37 120 6 hsync high vsync high endmode # # 800x600, 75 Hz, Non-Interlaced (49.50 MHz dotclock) # ... # mode "800x600-75" # D: 49.50 MHz, H: 46.875 kHz, V: 75.00 Hz geometry 800 600 800 600 8 timings 20203 160 16 21 1 80 3 hsync high vsync high endmode # # 800x600, 90 Hz, Non-Interlaced (56.64 MHz dotclock) # ... # mode "800x600-90" # D: 56.64 MHz, H: 57.097 kHz, V: 89.92 Hz geometry 800 600 800 600 8 timings 17656 120 8 16 8 64 11 hsync high vsync high endmode # # 800x600, 100 Hz, Non-Interlaced (67.50 MHz dotclock) # ... # mode "800x600-100" # D: 67.50 MHz, H: 62.500 kHz, V: 100.00 Hz geometry 800 600 800 600 8 timings 14815 216 0 14 7 64 4 hsync high vsync high endmode # # 1024x768, 43 Hz, Interlaced (44.90 MHz dotclock) # # Horizontal Vertical # Resolution 1024 768 # Scan Frequency 35.522 kHz 86.96 Hz # Sync Width 3.920 us 0.113 ms # 22 chars 8 lines # Front Porch 0.178 us 0.014 ms # 1 chars 1 lines # Back Porch 1.247 us 0.563 ms # 7 chars 40 lines # Active Time 22.806 us 10.810 ms # 128 chars 768 lines # Blank Time 5.345 us 0.690 ms # 30 chars 49 lines # Polarity positive positive # mode "1024x768-43-lace" # D: 44.90 MHz, H: 35.522 kHz, V: 86.96 Hz geometry 1024 768 1024 768 8 timings 22272 56 8 40 1 176 8 laced true hsync high vsync high endmode # # 1024x768, 60 Hz, Non-Interlaced (65.00 MHz dotclock) # # Horizontal Vertical # Resolution 1024 768 # Scan Frequency 48.363 kHz 60.00 Hz # Sync Width 2.092 us 0.124 ms # 17 chars 6 lines # Front Porch 0.369 us 0.062 ms # 3 chars 3 lines # Back Porch 2.462 us 0.601 ms # 20 chars 29 lines # Active Time 15.754 us 15.880 ms # 128 chars 768 lines # Blank Time 4.923 us 0.786 ms # 40 chars 38 lines # Polarity negative negative # mode "1024x768-60" # D: 65.00 MHz, H: 48.363 kHz, V: 60.00 Hz geometry 1024 768 1024 768 8 timings 15385 160 24 29 3 136 6 endmode # # 1024x768, 70 Hz, Non-Interlaced (75.00 MHz dotclock) # # Horizontal Vertical # Resolution 1024 768 # Scan Frequency 56.476 kHz 70.07 Hz # Sync Width 1.813 us 0.106 ms # 17 chars 6 lines # Front Porch 0.320 us 0.053 ms # 3 chars 3 lines # Back Porch 1.921 us 0.514 ms # 18 chars 29 lines # Active Time 13.653 us 13.599 ms # 128 chars 768 lines # Blank Time 4.053 us 0.673 ms # 38 chars 38 lines # Polarity negative negative # mode "1024x768-70" # D: 75.00 MHz, H: 56.476 kHz, V: 70.07 Hz geometry 1024 768 1024 768 8 timings 13334 144 24 29 3 136 6 endmode # # 1024x768, 72 Hz, Non-Interlaced (75.00 MHz dotclock) # # Horizontal Vertical # Resolution 1024 768 # Scan Frequency 58.230 kHz 72.245 Hz # Sync Width 1.813 us 0.103 ms # 17 chars 6 lines # Front Porch 0.320 us 0.052 ms # 3 chars 3 lines # Back Porch 1.387 us 0.498 ms # 13 chars 29 lines # Active Time 13.653 us 13.189 ms # 128 chars 768 lines # Blank Time 3.520 us 0.653 ms # 33 chars 38 lines # Polarity negative negative # mode "1024x768-72" # D: 75.00 MHz, H: 58.230 kHz, V: 72.245 Hz geometry 1024 768 1024 768 8 timings 13334 104 24 29 3 136 6 endmode # # 1024x768, 75 Hz, Non-Interlaced (78.75 MHz dotclock) # # Horizontal Vertical # Resolution 1024 768 # Scan Frequency 60.023 kHz 75.03 Hz # Sync Width 1.219 us 0.050 ms # 12 chars 3 lines # Front Porch 0.203 us 0.017 ms # 2 chars 1 lines # Back Porch 2.235 us 0.466 ms # 22 chars 28 lines # Active Time 13.003 us 12.795 ms # 128 chars 768 lines # Blank Time 3.657 us 0.533 ms # 36 chars 32 lines # Polarity positive positive # mode "1024x768-75" # D: 78.75 MHz, H: 60.023 kHz, V: 75.03 Hz geometry 1024 768 1024 768 8 timings 12699 176 16 28 1 96 3 hsync high vsync high endmode # # 1024x768, 90 Hz, Non-Interlaced (100.0 MHz dotclock) # # Horizontal Vertical # Resolution 1024 768 # Scan Frequency 76.220 kHz 90.20 Hz # Sync Width 0.960 us 0.197 ms # 12 chars 15 lines # Front Porch 0.000 us 0.276 ms # 0 chars 21 lines # Back Porch 1.920 us 0.537 ms # 24 chars 41 lines # Active Time 10.240 us 10.076 ms # 128 chars 768 lines # Blank Time 2.880 us 1.010 ms # 36 chars 77 lines # Polarity negative negative # mode "1024x768-90" # D: 100.0 MHz, H: 76.220 kHz, V: 90.20 Hz geometry 1024 768 1024 768 8 timings 10000 192 0 41 21 96 15 endmode # # 1024x768, 100 Hz, Non-Interlaced (110.0 MHz dotclock) # # Horizontal Vertical # Resolution 1024 768 # Scan Frequency 79.023 kHz 99.78 Hz # Sync Width 0.800 us 0.101 ms # 11 chars 8 lines # Front Porch 0.000 us 0.000 ms # 0 chars 0 lines # Back Porch 2.545 us 0.202 ms # 35 chars 16 lines # Active Time 9.309 us 9.719 ms # 128 chars 768 lines # Blank Time 3.345 us 0.304 ms # 46 chars 24 lines # Polarity negative negative # mode "1024x768-100" # D: 110.0 MHz, H: 79.023 kHz, V: 99.78 Hz geometry 1024 768 1024 768 8 timings 9091 280 0 16 0 88 8 endmode # # 1152x864, 43 Hz, Interlaced (65.0 MHz dotclock) # # Horizontal Vertical # Resolution 1152 864 # Scan Frequency 45.904 kHz 87.02 Hz # Sync Width 1.969 us 0.098 ms # 16 chars 9 lines # Front Porch 1.062 us 0.850 ms # 9 chars 78 lines # Back Porch 1.031 us 1.133 ms # 8 chars 104 lines # Active Time 17.723 us 9.411 ms # 144 chars 864 lines # Blank Time 4.062 us 2.080 ms # 33 chars 191 lines # Polarity positive positive # mode "1152x864-43-lace" # D: 65.0 MHz, H: 45.904 kHz, V: 87.02 Hz geometry 1152 864 1152 864 8 timings 15385 64 72 104 78 128 9 laced true hsync high vsync high endmode # # 1152x864, 47 Hz, Interlaced (65.0 MHz dotclock) # # Horizontal Vertical # Resolution 1152 864 # Scan Frequency 44.890 kHz 94.80 Hz # Sync Width 1.969 us 0.100 ms # 16 chars 9 lines # Front Porch 1.415 us 0.334 ms # 11 chars 30 lines # Back Porch 1.170 us 0.490 ms # 10 chars 44 lines # Active Time 17.723 us 9.624 ms # 144 chars 864 lines # Blank Time 4.554 us 0.924 ms # 37 chars 83 lines # Polarity positive positive # mode "1152x864-47-lace" # D: 65.0 MHz, H: 44.890 kHz, V: 94.80 Hz geometry 1152 864 1152 864 8 timings 15385 80 88 44 30 128 9 laced true hsync high vsync high endmode # # 1152x864, 60 Hz, Non-Interlaced (80.0 MHz dotclock) # # Horizontal Vertical # Resolution 1152 864 # Scan Frequency 54.945 kHz 59.98 Hz # Sync Width 1.400 us 0.091 ms # 14 chars 5 lines # Front Porch 0.800 us 0.109 ms # 8 chars 6 lines # Back Porch 1.600 us 0.746 ms # 16 chars 41 lines # Active Time 14.400 us 15.725 ms # 144 chars 864 lines # Blank Time 3.800 us 0.946 ms # 38 chars 52 lines # Polarity positive positive # mode "1152x864-60" # D: 80.0 MHz, H: 54.945 kHz, V: 59.98 Hz geometry 1152 864 1152 864 8 timings 12500 128 64 41 6 112 5 hsync high vsync high endmode # # 1152x864, 70 Hz, Non-Interlaced (100.0 MHz dotclock) # # Horizontal Vertical # Resolution 1152 864 # Scan Frequency 66.138 kHz 69.99 Hz # Sync Width 1.520 us 0.166 ms # 19 chars 11 lines # Front Porch 0.390 us 0.197 ms # 5 chars 13 lines # Back Porch 1.690 us 0.862 ms # 21 chars 57 lines # Active Time 11.520 us 13.064 ms # 144 chars 864 lines # Blank Time 3.600 us 1.225 ms # 45 chars 81 lines # Polarity positive positive # mode "1152x864-70" # D: 100.0 MHz, H: 66.138 kHz, V: 69.99 Hz geometry 1152 864 1152 864 8 timings 10000 168 40 57 13 152 11 hsync high vsync high endmode # # 1152x864, 75 Hz, Non-Interlaced (110.0 MHz dotclock) # # Horizontal Vertical # Resolution 1152 864 # Scan Frequency 75.137 kHz 74.99 Hz # Sync Width 1.309 us 0.106 ms # 18 chars 8 lines # Front Porch 0.245 us 0.599 ms # 3 chars 45 lines # Back Porch 1.282 us 1.132 ms # 18 chars 85 lines # Active Time 10.473 us 11.499 ms # 144 chars 864 lines # Blank Time 2.836 us 1.837 ms # 39 chars 138 lines # Polarity positive positive # mode "1152x864-75" # D: 110.0 MHz, H: 75.137 kHz, V: 74.99 Hz geometry 1152 864 1152 864 8 timings 9091 144 24 85 45 144 8 hsync high vsync high endmode # # 1152x864, 80 Hz, Non-Interlaced (110.0 MHz dotclock) # # Horizontal Vertical # Resolution 1152 864 # Scan Frequency 76.389 kHz 79.74 Hz # Sync Width 1.018 us 0.092 ms # 14 chars 7 lines # Front Porch 0.127 us 0.393 ms # 2 chars 30 lines # Back Porch 1.473 us 0.747 ms # 20 chars 57 lines # Active Time 10.473 us 11.311 ms # 144 chars 864 lines # Blank Time 2.618 us 1.231 ms # 36 chars 94 lines # Polarity positive positive # mode "1152x864-80" # D: 110.0 MHz, H: 76.389 kHz, V: 79.74 Hz geometry 1152 864 1152 864 8 timings 9091 160 16 57 30 112 7 hsync high vsync high endmode # # 1280x960, 75 Hz, Non-Interlaced (126.00 MHz dotclock) # # Horizontal Vertical # Resolution 1280 960 # Scan Frequency 74.788 kHz 74.788 Hz # Sync Width 1.018 us 0.092 ms # 14 chars 7 lines # Front Porch 0.127 us 0.393 ms # 2 chars 30 lines # Back Porch 1.473 us 0.747 ms # 20 chars 57 lines # Active Time 10.473 us 11.311 ms # 144 chars 864 lines # Blank Time 2.618 us 1.231 ms # 36 chars 94 lines # Polarity positive positive # mode "1280x960-75-8" # D: 125.644 MHz, H: 74.788 kHz, V: 74.788 Hz geometry 1280 960 1280 960 8 timings 7959 224 32 36 1 144 3 endmode mode "1280x960-75" # D: 125.644 MHz, H: 74.788 kHz, V: 74.788 Hz geometry 1280 960 1280 960 16 timings 7959 224 32 36 1 144 3 endmode mode "1280x960-75-32" # D: 125.644 MHz, H: 74.788 kHz, V: 74.788 Hz geometry 1280 960 1280 960 32 timings 7959 224 32 36 1 144 3 endmode # # 1280x1024, 43 Hz, Interlaced (80.00 MHz dotclock) # # Horizontal Vertical # Resolution 1024 1024 # Scan Frequency 50.000 kHz 87.03 Hz # Sync Width 1.000 us 0.100 ms # 10 chars 10 lines # Front Porch 1.000 us 0.500 ms # 10 chars 50 lines # Back Porch 2.000 us 0.650 ms # 20 chars 65 lines # Active Time 16.000 us 10.240 ms # 160 chars 1024 lines # Blank Time 4.000 us 1.250 ms # 40 chars 125 lines # Polarity positive positive # mode "1280x1024-43-lace" # D: 80.00 MHz, H: 50.000 kHz, V: 87.03 Hz geometry 1024 1024 1024 1024 8 timings 12500 160 80 65 50 80 10 laced true hsync high vsync high endmode # # 1280x1024, 47 Hz, Interlaced (80.00 MHz dotclock) # # Horizontal Vertical # Resolution 1280 1024 # Scan Frequency 50.000 kHz 94.97 Hz # Sync Width 1.000 us 0.100 ms # 10 chars 10 lines # Front Porch 1.000 us 0.010 ms # 10 chars 1 lines # Back Porch 2.000 us 0.180 ms # 20 chars 18 lines # Active Time 16.000 us 10.240 ms # 160 chars 1024 lines # Blank Time 4.000 us 0.290 ms # 40 chars 29 lines # Polarity positive positive # mode "1280x1024-47-lace" # D: 80.00 MHz, H: 50.000 kHz, V: 94.97 Hz geometry 1280 1024 1280 1024 8 timings 12500 160 80 18 1 80 10 laced true hsync high vsync high endmode # # 1280x1024, 60 Hz, Non-Interlaced (108.00 MHz dotclock) # # Horizontal Vertical # Resolution 1280 1024 # Scan Frequency 63.981 kHz 60.02 Hz # Sync Width 1.037 us 0.047 ms # 14 chars 3 lines # Front Porch 0.444 us 0.015 ms # 6 chars 1 lines # Back Porch 2.297 us 0.594 ms # 31 chars 38 lines # Active Time 11.852 us 16.005 ms # 160 chars 1024 lines # Blank Time 3.778 us 0.656 ms # 51 chars 42 lines # Polarity positive positive # mode "1280x1024-60" # D: 108.00 MHz, H: 63.981 kHz, V: 60.02 Hz geometry 1280 1024 1280 1024 8 timings 9260 248 48 38 1 112 3 hsync high vsync high endmode # # 1280x1024, 70 Hz, Non-Interlaced (126.00 MHz dotclock) # # Horizontal Vertical # Resolution 1280 1024 # Scan Frequency 74.645 kHz 70.02 Hz # Sync Width 0.889 us 0.067 ms # 14 chars 5 lines # Front Porch 0.635 us 0.013 ms # 10 chars 1 lines # Back Porch 1.714 us 0.483 ms # 27 chars 36 lines # Active Time 10.159 us 13.718 ms # 160 chars 1024 lines # Blank Time 3.238 us 0.563 ms # 51 chars 42 lines # Polarity positive positive # mode "1280x1024-70" # D: 126.00 MHz, H: 74.645 kHz, V: 70.02 Hz geometry 1280 1024 1280 1024 8 timings 7937 216 80 36 1 112 5 hsync high vsync high endmode # # 1280x1024, 74 Hz, Non-Interlaced (135.00 MHz dotclock) # # Horizontal Vertical # Resolution 1280 1024 # Scan Frequency 78.855 kHz 74.11 Hz # Sync Width 1.067 us 0.380 ms # 18 chars 30 lines # Front Porch 0.237 us 0.000 ms # 4 chars 0 lines # Back Porch 1.896 us 0.127 ms # 32 chars 10 lines # Active Time 9.481 us 12.986 ms # 160 chars 1024 lines # Blank Time 3.200 us 0.507 ms # 54 chars 40 lines # Polarity positive positive # mode "1280x1024-74" # D: 135.00 MHz, H: 78.855 kHz, V: 74.11 Hz geometry 1280 1024 1280 1024 8 timings 7408 256 32 10 0 144 30 hsync high vsync high endmode # # 1280x1024, 75 Hz, Non-Interlaced (135.00 MHz dotclock) # # Horizontal Vertical # Resolution 1280 1024 # Scan Frequency 79.976 kHz 75.02 Hz # Sync Width 1.067 us 0.038 ms # 18 chars 3 lines # Front Porch 0.119 us 0.012 ms # 2 chars 1 lines # Back Porch 1.837 us 0.475 ms # 31 chars 38 lines # Active Time 9.481 us 12.804 ms # 160 chars 1024 lines # Blank Time 3.022 us 0.525 ms # 51 chars 42 lines # Polarity positive positive # mode "1280x1024-75" # D: 134.880 MHz, H: 79.905 kHz, V: 74.958 Hz geometry 1280 1024 1280 3264 8 timings 7414 232 64 38 1 112 3 hsync high vsync high endmode # # 1600x1200, 60 Hz, Non-Interlaced (156.00 MHz dotclock) # # Horizontal Vertical # Resolution 1600 1200 # Scan Frequency 76.200 kHz 60.00 Hz # Sync Width 1.026 us 0.105 ms # 20 chars 8 lines # Front Porch 0.205 us 0.131 ms # 4 chars 10 lines # Back Porch 1.636 us 0.682 ms # 32 chars 52 lines # Active Time 10.256 us 15.748 ms # 200 chars 1200 lines # Blank Time 2.872 us 0.866 ms # 56 chars 66 lines # Polarity negative negative # mode "1600x1200-60" # D: 156.00 MHz, H: 76.200 kHz, V: 60.00 Hz geometry 1600 1200 1600 1200 8 timings 6411 256 32 52 10 160 8 endmode # # 1600x1200, 66 Hz, Non-Interlaced (172.00 MHz dotclock) # # Horizontal Vertical # Resolution 1600 1200 # Scan Frequency 82.700 kHz 66.00 Hz # Sync Width 0.791 us 0.036 ms # 17 chars 3 lines # Front Porch 0.233 us 0.036 ms # 5 chars 3 lines # Back Porch 1.767 us 0.567 ms # 38 chars 47 lines # Active Time 9.302 us 14.512 ms # 200 chars 1200 lines # Blank Time 2.791 us 0.532 ms # 60 chars 44 lines # Polarity negative negative # mode "1600x1200-66" # D: 172.00 MHz, H: 82.700 kHz, V: 66.00 Hz geometry 1600 1200 1600 1200 8 timings 5814 304 40 47 3 136 3 endmode # # 1600x1200, 76 Hz, Non-Interlaced (198.00 MHz dotclock) # # Horizontal Vertical # Resolution 1600 1200 # Scan Frequency 95.200 kHz 76.00 Hz # Sync Width 0.687 us 0.052 ms # 17 chars 5 lines # Front Porch 0.202 us 0.032 ms # 5 chars 3 lines # Back Porch 1.535 us 0.441 ms # 38 chars 42 lines # Active Time 8.081 us 12.606 ms # 200 chars 1200 lines # Blank Time 2.424 us 0.525 ms # 60 chars 50 lines # Polarity negative negative # mode "1600x1200-76" # D: 198.00 MHz, H: 95.200 kHz, V: 76.00 Hz geometry 1600 1200 1600 1200 8 timings 5051 304 40 42 3 136 5 endmode picuntu@g8picuntu:~$
/Install.sh
reboot
/Install.sh
reboot
There are currently 2264 users online. 2 members and 2262 guests.
