PicUntu-4.5-nand-BasicGUI installer - One file, few click install.
It seems both of my sticks are running at 1.2ghz after flashing Linux (PicUntu and Linuxium).
Code:cat /sys/devices/system/cpu/cpu0/cpufreq/cpuinfo_cur_freg
Here is a good link of how you can set the frequencies of your stick.
http://blog.tube42.se/?p=1225
do aCode:cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies
Hello,
does exist an easy way to change video resolution?
My tv is hdready, not full hd. It can handle 1920x1080 but resample is very ugly.
A 720p kernel would be perfect...
I've tried with fbset but results are always bizarre...
I've a QC802 (MK802 IV clone with 6210 wifi chipset).
Thanks...
Agreed on 720p version
Thanks...
Re: PicUntu-4.5-nand-BasicGUI installer - One file, few click install.
I HAVE SUCCESSFULLY FLASHED MY NETXEON MK809III V1.0. BUT I DONT KNOW TO PASS FOR ROOT.
I M ALSO FACING STRANGE PROBLEM. I M USING ONIDA FULL HD LCD TV AND FROM BEGINNING WHEN BOOTING START MY DISPLAY IS OUT OF SCREEN AREA( ALL OF THE FOUR SIDE GOING OUTSIDE DISPLAY AREA) AND MY DISPLAY IS GOING BLANK AND AFTER FEW SEC IT COMES BACK AGAIN GOING BLANK AND AFTER FEW SEC IT COMES BACK THIS HAPPENNING CONTINUOUSLY.
I M UNABLE TO TEST OTHER THINGS CAUSE I DON'T HAVE PHYSICAL KEYBOARD SO PLEASE ADD VIRTUAL KEYBOARD IF POSSIBLE FOR THOSE WHO DON'T HAVE PHYSICAL KEYBOARD LIKE ANDROID
Sent from my MIUI By Java using Tapatalk 2
I have installed Ubuntu from this post http://www.freaktab.com/showthread.p...l=1#post109194
on my mk908 v5, but it can't load in graphics interface. I've got a message like "system run in low graphics mode" and no ubuntu desktop appears.
How can i fix this? It is neccessary to install video driver or something else?
Now i can boot into command line, and it's working ok, but x-server do not start.
upd:
If i break down to command line with Ctrl+Alt+F1 and run 'startx', i get a ubuntu-like desktop with same color background, but no menu's and so on.
Here is screenshot https://www.dropbox.com/s/er60f10lzg...225_173157.jpg
Hi, now i have reinstalled picuntu for mk908 distr. It loads and works, i have installed some software like vsftp and apache2. And it works ok too.
Also i need some application development. For it i have installed QDevelop via Synaptic Package Manager.
And i have it cruhes when building project from IDE, if i build project from console, it builds ok.
Error - "segmentation fault" when builing from IDE.
Second problem - device suddenly reboots. My suggestion - is overheating, but i run stress utility, wich loads cores for 100% and device continues running.
It works!
Today i flashed image ubuntu-12.04 from whis post http://www.gizfun.com/content/instal...ksmk908mk802iv in 'system' block of nand
Then i've resized root parition with commands (i've took this command from rc.local of vmkogeretla's image, thanks to him)
Code:resize2fs -p /dev/mtdblock2 mount -o remount,rw /dev/mtdblock2
For installing applications (like chromium) you need update packages with
Code:apt-get update
But color depth is low, i think it 16bits per pixel. Is color depth configured in kernel or somewhere else?
MK908 - Wifi stops after some time
Originally posted by mustafaupk View PostThank you gmtii. Your kernel here works really well. I flashed it onto my mk908v3 and now it doesn't have the problem with requiring root for network based activities (i.e. firefox/chromium).
A new request for your: Is it possible to compile a kernel with 1920x1080 output?
I want to use it as a little web/dev/files/scripting server, so a stable wifi connexion would be usefull
Anyway, thanks a lot for all this work !
blinking screen MK908V3
Somebody please help me fixing the screen blinking issue with my MK908v3. The HDMI output is constantly switching on and off every 1-2seconds. I've flashed the images below.
Beside this everything else is working, wifi as well. (The same happens when I boot from an external USB the linuxium image with a recovery image.)
Is there anybody experiencing this problem?
Thx for your help in advance
Originally posted by goldenfly View PostFirst of all, a huge thanks to Alok, as well as the entire PicUntu team and community members, for your hard work in getting PicUntu onto RK3188 devices!
Following the postings from gmtii and alok's response, I've re-compressed a version of the installer 7z (DOWNLOAD HERE) which contains an updated system.img that includes Omegamoon's 3.0.72+ kernel modules (/lib/modules/3.0.72+/ folder copied from gmtii's archive, /lib/modules/*.ko.3.0.72+ compiled from omegamoon's git repo), as well as gmtii's compiled kernel_nand.img and kernel_sd.img. I hope that this can allow more people to try out PicUntu on their MK908 devices!
Flashing Instructions (derived from Alok's; tested on MK908 v3):
0. Make sure you have the Rockchip device drivers installed on your Windows PC. You can use Google to find instructions. Also, read Alok's original post before continuing.
1. On a Windows PC, download and uncompress PicUntu-4.5-BasicGUI-Nand-MK908v3.7z.
2. Run rk_flash_1.37/RKAndroidTool.exe. Every entry except for misc, recovery, and backup should be checked.
3. Disconnect all USB connections to your MK908 device; make sure a USB-to-mini-USB cable is connected to your PC.
4. While holding down the reset/flash button (accessed via the small hole near the HDMI jack that does not light up during normal boot-up), connect the mini-USB cable to the side mini-USB jack (labelled OTG). Hold for 2+ seconds until RkAndroidTool.exe reports "Device Found for Flashing". (If this does not happen, make sure you have the Rockchip device drivers installed)
5. Click on Erase NAND and wait until messages stop (~20 sec)
6. Click on Flash ROM and wait until messages stop (~3 mins)
Currently, you need to manually load the wifi module on every boot, although you can probably create an upstart/init.d script/cronjob/etc. script to do this automatically.
7. Once you log into PicUntu, open up a Terminal (2nd icon in the bottom launchpad).
8. Type 'sudo insmod /lib/modules/rkwifi.ko.3.0.72+', and enter password when prompted.
(Edit: there seems to be a permission issue after running this command, where only root user can access internet -- ping/ssh/apt/wget/firefox/etc all fails under picuntu user. Try removing the sudo when running the insmod command... I have yet to test this since I'm in the middle of compiling.)
9. Enjoy PicUntu on your MK908 device!
I'm in the process of configuring a MK908 to control an AR.Drone quadrotor autonomously using OpenCV and ROS. More on that soon (I hope)
Sidenote: to find out what is the board version of you MK908, you need to open the case (by slowly propping it open using a spadger/ flat screwdriver/etc), and look for the text "MK908 V3.0 2013/05/13" on the side with the reset/flash button, near the OTG mini-USB jack.
P.S. to Alok: in RkAndroidTool.exe, you can right-click on the list of items and export an updated flash configuration into config.cfgAttached Files
Originally posted by mlck View PostSomebody please help me fixing the screen blinking issue with my MK908v3. The HDMI output is constantly switching on and off every 1-2seconds. I've flashed the images below.
URL here: https://github.com/aloksinha2001/Linux3188/issues/23
There are currently 2492 users online. 0 members and 2492 guests.
